Author Topic: Rns 510 canbus questions  (Read 1534 times)
Offline Patters78
« on: August 14, 2015, 06:39:04 pm »
Hi everyone
I have today finally brought a rns 510 version c LED :) 330 quid
Now my question regarding getting it too work,  firstly though my main aim eventually is rns, reverse cam, mfsw, highline cluster, Bluetooth, mid in unit.
With that in mind on to my car Jetta 2006 TDI
With that in mind onto my canbus
After loads of reading I think I'm right in saying I need rev K or higher that stop bat drain? But will it enable me to do the other things?
I have seen a Jetta version k for 24.99 which is really cheap
Also can I get a canbus from golf if needed?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Rns 510 canbus questions
« Reply #1 on: August 14, 2015, 07:04:45 pm »
You need a L revision or from Q to later revisions. Just one of the K revisions with the correct firmware is compatible so I wouldn't waste my time searching for them.
Offline Patters78
« Reply #2 on: August 14, 2015, 08:48:39 pm »
Right ok so if Im getting this right.
K revision has only 1 firmware that's compatible (can that not be flashed via vcds?)
L revision is fine but anything between L and Q isn't?
Then all above Q is good
Offline Pashka
« Reply #3 on: August 14, 2015, 10:00:56 pm »
It can be flashed with VAS or other tools, but not VCDS. Dealer charges more than a new one used cost.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
