Author Topic: Ram Air Induction Kit  (Read 33482 times)
Offline jasam
  • My Ride: 2.0 tfsi k04, revo stage 3
Re: Ram Air Induction Kit
« Reply #60 on: April 06, 2016, 07:41:12 pm »
Much better than the Forge Twintake!!!  :signLOL:
Up to around 5% on the LTFT when I tried a RamAir MAF tube/scaling on Revo software, but the LTFT is not indicative of peak readings, it is only a blanket correction added to the RPM range under mixed load conditions, i.e. normal driving
did you log  lambda adaptation/ regulator ? how much percentage you get with your filter or ramair, ar full throttle, peak power? do you have any log?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #61 on: April 06, 2016, 08:00:29 pm »
Mine stays within + or - 5%, but i do have Meth injection which will affect this too. Thats with my current intake - dont have any logs for the RamAir MAF pipe
Offline jasam
« Reply #62 on: April 06, 2016, 08:07:36 pm »
Ok. as my ltft are 10-13%. But my lambda regulator is at 25%. I hope its connected with not so ideal forge twintake maf housing.. will see. cannt find k04 logs with twintake on internet (with lambda regulator included in log)
Offline siggik
« Reply #63 on: August 23, 2016, 11:35:45 pm »
Hey guys, i just bought the oversized intake, the "manual" is sh*t  :laugh:
but my proplem is since i got k04, how do i connect the hose to the bung ??
the small hose that connected to the old turbo intake is just sitting there open
2007 ED30 btw
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #64 on: August 24, 2016, 10:24:49 am »
2007 ED30 btw
Did you get the k04 version or k03?
The k04 one should have a nipple tube for the other hose to go on before the maf.
Offline unzippy
« Reply #65 on: August 24, 2016, 03:52:58 pm »
Black clamps look very good, mine came with shiny ones.
Offline siggik
« Reply #66 on: August 24, 2016, 07:51:19 pm »
2007 ED30 btw
yes i got the k04 one, the bung and all
but my "noise" pipe and other pipes look alot diffrent than what are pictured
mine looks like this, way bigger than the bung for example
http://s1313.photobucket.com/user/arturb19/media/EngineBay_zps647edd4c.jpg.html
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #67 on: August 24, 2016, 09:17:56 pm »
2007 ED30 btw
Is yours LHD? LHD Ed. 30 have the noise generator and the corresponding pipe. You need to do the same as I did to mine. I relocated the DV to the front of the engine like the RHD Ed. 30. :wink:
Check my build topic: http://www.mk5golfgti.co.uk/forum/index.php/topic,95592.240.html
Offline ducman77
  • -Given: 59
« Reply #68 on: August 24, 2016, 11:16:55 pm »
I've just fitted the 90mm oversize to my K03 stage 1 GTI. The car has a full turbo back 3in exhaust (no cat). The intake has made quite a lot more power than I was expecting. But my fuel economy has plummeted?? 280mls from a full tank?? WTF??:doh: :doh:
Anyone else heard of this happening?
I'm hopefully fitting an Intercooler in the next month or two and then it's back to the tuner for stage 2 Mapping where I'm sure he'll be able to claw back some fuel economy for me??
Anyone any thoughts on this?
Also, just a heads up for anyone thinking of fitting this intake. The sound of the turbo gulping in air even in light acceleration is really very noticeable. It's present all the time unless you're totally off the throttle. Not necessarily a bad thing. But just thought I'd mention it as I wasn't expecting it and I imagine some people might find it pretty off putting. There's no typical induction roar like you get on a naturally aspirated car. Just lots of giant Hoover like sucking sounds :smiley: :happy2:
Offline unzippy
« Reply #69 on: August 25, 2016, 01:19:36 pm »
You like the noises so much you are mashing the pedal harder? :grin:
Offline slix
  • -Receive: 38
« Reply #70 on: August 25, 2016, 02:52:15 pm »
The ram air makes a horrible noise  :doh:
Offline ducman77
  • -Given: 59
« Reply #71 on: August 25, 2016, 03:11:49 pm »
This is a distinct possibility  :happy2: :laugh: :smiley:
I'm kinda inclined to agree with you! It ain't subtle and it ain't pretty :laugh:
Do you have any experience of any others that sound better?
I drove an edition 30 with an EVOMS intake and that wasn't very nice either :ashamed:
Does anyone make an induction kit for this car that actually sounds good??
Offline unzippy
« Reply #72 on: August 25, 2016, 03:14:18 pm »
To be fair, if you make more power you will use more fuel...
Offline ducman77
  • -Given: 59
« Reply #73 on: August 25, 2016, 03:30:55 pm »
100% agree :happy2:
I'd been keeping an eye on it since going stage 1 map. If anything the map improved economy a little bit.
When I installed the 3in turbo it made a lot more power and hurt the economy just a little.
But when I installed the RamAir it made a little bit more power but the fuel economy plummeted?? It's really weird. I presume it's all in the map or fuel trims or whatever?
I'm ok with spanners but i am a total numpty when it comes to mapping :ashamed: :ashamed:
My feeling is that it's running rich in the cruise portion of the map probably to compensate for the extra air passing the MAF sensor?
The only reason I say that is because on a recent long, boring and steady motorway drive it just gobbled up all my fuel even though my right foot was being parsimonious :laugh: :laugh:
Anyway, POWA is so much important than economy anyways... So who cares :smiley: :smiley: :happy2:
Offline dronners
« Reply #74 on: August 25, 2016, 03:51:42 pm »
must say noise dosent bother me.  i've heard it be compared to an out of tune flute before. i kinda like the whooshy harmonics
