Author Topic: Water leak please help.  (Read 2164 times)
Offline perksy
« on: August 17, 2015, 12:13:12 pm »
Hi there.
I've got a water leak from under the drivers side of the car beneath the drivers footwell.  Its pure water as far as I can tell.  Not greasy at all and there's quite a lot of it.
I've google searched and found this youtube vid which is EXACTLY the same problem as me.
Can anyone help?  Hoping its not a porous engine block or a heater matrix!
James
Offline neiller
  • -Given: 32
Re: Water leak please help.
« Reply #1 on: August 17, 2015, 01:19:24 pm »
The coolant coming from your engine/heater matrix should be pink like the stuff in the expansion tank is it anything to donwith the air con ?
Sent from my SM-N9005 using Tapatalk
Offline doylebros
« Reply #2 on: August 17, 2015, 07:42:33 pm »
One expects that would be a result of running the air con and isn't a fault it part of the process.
Offline Washout
« Reply #3 on: August 17, 2015, 09:29:48 pm »
Had the same thing on my car the other day small pool of water in exactly the same spot had me worried. Iike you say not greasy or smelly. Its from the air con unit. The trucks in work do it frequently you can hear it trickling sometimes.
Offline Matthewsimone
  • -Receive: 39
« Reply #4 on: August 17, 2015, 10:00:50 pm »
Most cars with aircon do this mine included
Our old mk4 Gt was like a trickling tap  :laugh:m
Nothing to worry about mate  :happy2:
