Author Topic: 2015 Updates inc Nav Map - Kenwood DNX520VBT [link inside] :)  (Read 19641 times)
Offline xjay1337
  • -Receive: 377
Re: 2015 Updates inc Nav Map - Kenwood DNX520VBT [link inside] :)
« Reply #15 on: November 03, 2015, 05:48:34 pm »
Bump.
Offline petesimcock
« Reply #16 on: November 06, 2015, 06:53:12 am »
Haven't got round to downloading this yet, am I right that I can flash this on using the sd slot on the front of the unit? I'm sure I read something about the back of the unit for map updates, maybe if you don't want to use sd.
Offline hlcst
« Reply #17 on: November 06, 2015, 08:11:50 am »
The back is used to load the map directly to the unit and replace the old one but it's a lot easier just to leave your sd card in the slot
Offline xjay1337
  • -Receive: 377
« Reply #18 on: November 06, 2015, 09:56:28 am »
Ah I didn't know that! I may pop my HU out because I need the 16GB MicroSD card for my photos lol.
Did wonder how I could remove the 2011 maps...
Offline hlcst
« Reply #19 on: November 06, 2015, 12:19:56 pm »
You need to do it by connecting the HU to a laptop
Offline xjay1337
  • -Receive: 377
« Reply #20 on: November 06, 2015, 12:51:17 pm »
I will try that! I'm assuming there's a port on the back of the head unit? Or do you connect to the USB?
The webpage I use for guides for this HU doesn't mention that.
Offline hlcst
« Reply #21 on: November 06, 2015, 01:06:24 pm »
You just use the USB, I was toying with the idea of plugging a mini USB to USB cable in the back and sending it into the glove box so I could access it when needed. Basically you just drag and drop the files
Some info I found:
Mini-USB port
The mini-USB port found on the back of the DNX520VBT is an undocumented port that enables the user to access the Garmin map folders built into the unit to update files within the Garmin folder. Please note if you do update any files or folders via this method to make a full backup of the Garmin folder before any updating is done.
Offline Matt81
  • -Given: 47
« Reply #22 on: June 28, 2016, 03:49:13 pm »
I think I've found a way to update these to the new 2016 maps.
I've just installed in my car and will test after work.
Offline Matt81
  • -Given: 47
« Reply #23 on: June 29, 2016, 12:49:55 pm »
OK so the 2016 map update worked - yay!
If anyone is interested let me know and I'll post the how to on here.
Offline xjay1337
  • -Receive: 377
« Reply #24 on: June 29, 2016, 03:29:30 pm »
Please mate if you could! :-)
Offline Matt81
  • -Given: 47
« Reply #25 on: June 29, 2016, 03:53:13 pm »
I'm uploading the required file now and will share link when done.
Quite pleased with it as 2016 isn't even officially available direct from Kenwood yet (I used the unlocked map file from a more recent head unit).
Basically, as long as you have completed the 2015 update process in this thread you can just replace the gmapsupp.img file on your SD and BOOM 2016 maps.
Also if your SD card is big enough you can re-name your existing file to gmapsup1.img and you can have both installed and change between them if you like (I just left it on in case in issue with 2016 maps).
Offline xjay1337
  • -Receive: 377
« Reply #26 on: June 29, 2016, 05:09:09 pm »
Ah that's handy! Clever guy  :happy2: :happy2:
I have the 2011 maps on the Head Unit and 2015 maps on my memory card.
I will move the 2016 maps to the HU and keep the 2015 maps on the card for a while to ensure no issues.
Offline Matt81
  • -Given: 47
« Reply #27 on: June 29, 2016, 05:14:15 pm »
Here is the link.
https://mega.nz/#!0UMA3ICI!hee2s7vrPp6uszAU42s0yZCNHo-xD0XoUDKCP39vt4Y
Remember to tick the 2016 maps in settings>maps>info
Offline xjay1337
  • -Receive: 377
« Reply #28 on: June 29, 2016, 05:34:26 pm »
Here is the link.
wicked mate thanks downloaded it now :-) yay for central london internet speed lol
replace the gmapsupp.img file on the existing map file?
so for me as i want to update my HU i'll need to overwrite the 2011 maps on the HU and then copy this 2016 file to that.
Offline Matt81
  • -Given: 47
« Reply #29 on: June 29, 2016, 05:36:16 pm »
I'm not sure about the Hu maps. I just replaced the SD one.
Sent from my SM-N910F using Tapatalk
