Author Topic: Stage 2+ ed30  (Read 7322 times)
Offline P30egy
Stage 2+ ed30
« on: August 18, 2015, 11:10:44 am »
Ed30 with miltek tb with decat
Revo intake
Auto tech pump
Revo stage 2+
Dsg stage 2
Car was run in 5th gear on dyno and made 315bhp
Which is nowhere near what revo claim. Any ideas why
Offline Madone
  • -Receive: 27
Re: Stage 2+ ed30
« Reply #1 on: August 19, 2015, 12:23:47 pm »
Is that at the wheels or crank ?, not sure about transmission losses but maybe that is about right for wheel horse power at 2+ ?
What settings did you have ?, boost, fuel, timing ?, I am sure you can turn down stage 2+ to 315 at the crank with the wrong settings
Offline Paradox1
  • -Given: 41
Re: Stage 2+ ed30
« Reply #2 on: August 19, 2015, 12:33:51 pm »
you may want to invest in a intercooler
Offline Dan648v
  • -Given: 28
Re: Stage 2+ ed30
« Reply #3 on: August 19, 2015, 01:11:42 pm »
Bit weird for a dyno pull to be done in 5th gear? Most I've had done and seen are in 4th
Offline GTi-Andy
Re: Stage 2+ ed30
« Reply #4 on: August 19, 2015, 01:21:29 pm »
IC would be my guess
So much for keeping it standard!
Offline P30egy
Re: Stage 2+ ed30
« Reply #5 on: August 19, 2015, 01:22:27 pm »
Intercooler is on my to do list which seems to be endless, he said 5th because there was to much wheel spin in 4th. I don't know about setting I just let the tuner do that.
I also have a recurring problem with code p2177 the light wasn't on but came on not long after the run? I've changed lambda sensor and fuel pump internals and rebuilt the pump but the light is back on, I'm thinking maf?
Offline P30egy
Re: Stage 2+ ed30
« Reply #6 on: August 19, 2015, 01:23:30 pm »
To add the car ran 309hp on the second run so they opened the bonnet a little for the 3rd because of the temps.
Offline Dan648v
  • -Given: 28
Re: Stage 2+ ed30
« Reply #7 on: August 19, 2015, 02:45:03 pm »
Where did you get it dynod? And do you remember the make of rollers?
Offline P30egy
Re: Stage 2+ ed30
« Reply #8 on: August 19, 2015, 02:46:24 pm »
scoob clinic, dyno dynamics
Offline Paradox1
  • -Given: 41
Re: Stage 2+ ed30
« Reply #9 on: August 19, 2015, 03:04:40 pm »
Would have thought the bonnet should have been open anyway.
Id say get a cooler on first then see if it picks up on the next map.
Did you get a dyno print out that you can post on here?
Offline Dan648v
  • -Given: 28
Re: Stage 2+ ed30
« Reply #10 on: August 19, 2015, 04:26:09 pm »
They must get some high power cars on there so surprised to see it spin in 4th?
Can't remember off the top of my head but sure the ratio in 4th is closet to 1:1 as it can be without the engine out, making the figure more accurate where as in fifth it won't be making your bhp read out of character. Maybe a garage on here could explain, could be wrong @Statller-Stevo . @hurdy
Offline Madone
  • -Receive: 27
Re: Stage 2+ ed30
« Reply #11 on: August 19, 2015, 07:44:02 pm »
A new IC will help you after the first run once the temps get up, but you should at least get one run with power in the area you are expecting. Don't buy a IC and expect to gain 50bhp, IC gives you consistency. If you are down on power that much look elsewhere first.
  • -Receive: 427
Re: Stage 2+ ed30
« Reply #12 on: August 19, 2015, 07:53:27 pm »
Something not right there, mine ran well over that at stage 1.5 (although RTech). Assuming it's run on 99RON?
check DV and yes IC and a FPRV are also needed. As mentioned, post a pic of your graph?
Offline P30egy
Re: Stage 2+ ed30
« Reply #13 on: August 19, 2015, 11:53:34 pm »
[/quote
It's running on vpower, I'm going to order a dv and try that, ic and rs4 fpv also. I'm not sure how to upload pictures
Offline Madone
  • -Receive: 27
Re: Stage 2+ ed30
« Reply #14 on: August 20, 2015, 07:35:06 am »
Can you get vagcom and do some logging ?, before you shell out on other bits check what the actual issue is. Actual verses requested boost will tell you about the DV (and a visual check). Actual and request rail pressure will check the fuel pump. And intake temp will see how hot things are getting. For stage 2+ you need these parts but it's worth being scientific about it to nail the problem. Could be a boost leak in a hose, PCV valve ?, low settings on REVO ?, could be loads of things. I'd get some logs mate.
