September 30, 2024, 07:18:14 am
General
Random Chat
Pressure washer without water mains
Topic: Pressure washer without water mains (Read 1417 times)
Chris92
Won't Shut up.
-Given: 33
-Receive: 35
If you're smart in this world they call you crazy
My Ride:
August 18, 2015, 11:11:12 pm »
Can I feed a electric pressure washer with a tank/drum of water instead of having to have it connected to the water mains?
Last Edit: August 18, 2015, 11:20:51 pm by Chris92
DANBOY66
Just look at my post count
-Given: 41
-Receive: 55
My Ride:
Re: Pressure washer without water mains
Reply #1 on:
August 19, 2015, 09:49:01 am »
it should work fine
Dan..
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #2 on:
August 19, 2015, 09:54:08 am »
Yep.... will work. Just get some sort of filter to make sure no crap gets sucked into the unit.
https://www.justgiving.com/thenational3peaks
Horatio
Won't Shut up.
-Given: 23
-Receive: 39
Reply #3 on:
August 19, 2015, 12:26:45 pm »
drop the water feed in a bucket, preferably bigger the better
john87
Won't Shut up.
-Given: 11
-Receive: 53
Reply #4 on:
August 19, 2015, 12:35:25 pm »
also worth noting, try and keep the hose from the container to the washer as short as reasonably possible (2/3 metres or less ideally) or you're gonna shorten your pumps' lifespan a little
Chris92
Won't Shut up.
-Given: 33
-Receive: 35
My Ride:
Reply #5 on:
August 19, 2015, 10:35:10 pm »
Thanks for the help and advice
Tal001
Taking part
-Given: 7
-Receive: 1
Reply #6 on:
August 19, 2015, 11:00:20 pm »
Yes it will work fine. I have just bought a karcher which I use off a water butt, it works perfectly.
General
Random Chat
