Author Topic: supply and fitting new car stereo on MK5 Golf  (Read 8393 times)
Offline Ozzy82
  • -Given: 28
« on: August 19, 2015, 03:09:53 pm »
I would like to upgrade my RCD300 to a newer system (either the RCD510 or a RNS system). Can anybody advise me on the best place to start on finding a system, then fitting it?
Many Thanks
Offline andy7ven
  • -Receive: 30
Re: supply and fitting new car stereo on MK5 Golf
« Reply #1 on: August 23, 2015, 02:38:08 pm »
eBay is a good place lots of units for sale on there... Need to be careful what your buying though...
Or you could go to a company that does retrofits but it's going to be a more costlier option...
You may also have to factor in the price of upgrading your CANBUS module depending on the year of your car (Flat battery if you don't!)...
Also a DAB aerial if the unit needs it...
Or you could go down the route of a Kenwood DNX521/525 OEM looking and just a straight swap over, no need to upgrade CANBUS either
Offline Ozzy82
  • -Given: 28
« Reply #2 on: August 23, 2015, 04:11:41 pm »
Thanks! I have sat on ebay and also checked gumtree daily to find a decent RNS510 and and seeing roughly £350+ for the unit. But am confused by software version, item a,b,c - h etc etc
Offline Ozzy82
  • -Given: 28
« Reply #3 on: August 23, 2015, 04:13:15 pm »
Which rns510 will fit my MK5 2005/55 plate golf without canbus upgrade/battery drain? Or am i better off getting a canbus upgrade anyways? And after getting canbus upgraded can i choose any system?
Offline andy7ven
  • -Receive: 30
« Reply #4 on: August 23, 2015, 05:12:21 pm »
If yours is a 05/55 then it definitely will need upgrading...
Yes if it's done then you can fit all the latest VW headunits. The newer RNS510's have LED screen also some have DAB...  :confused:
Offline Ozzy82
  • -Given: 28
« Reply #5 on: August 23, 2015, 05:24:23 pm »
 :happy2: Right! So a canbus upgrade AND an RNS510 is on my shopping list... I've seen a system but where can i find a canbus ??  :scared: :confused:
Offline doylebros
« Reply #6 on: August 23, 2015, 06:05:35 pm »
Get in touch with Eddie-NL  a member on here - he'll precode you a new one so its plug and play :happy2:
Offline Pashka
« Reply #7 on: August 23, 2015, 06:46:43 pm »
I have a right canbus and could fit the radio. Cheers
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Ozzy82
  • -Given: 28
« Reply #8 on: August 23, 2015, 08:14:48 pm »
Thanks! I have enough posts now (wahay!) so have just pm'd him
Offline doylebros
« Reply #9 on: August 23, 2015, 08:19:25 pm »
Eddie is a top top man and is very fair with his pricing
Offline Ozzy82
  • -Given: 28
« Reply #10 on: August 23, 2015, 08:36:34 pm »
Thanks! Alot of people on here have said that. How much should i be looking to pay for a decent, newish version of the RNS510? The prices vary sooo much
Offline doylebros
« Reply #11 on: August 23, 2015, 08:39:58 pm »
Again ask Ed if he's got any for sale if not what you need to look out for in model types, specification and firmware etc.
Offline Ozzy82
  • -Given: 28
« Reply #12 on: August 27, 2015, 09:10:55 pm »
Need some advice please! Which version of the RNS510 should i be looking at? I have seen a few on ebay/Guntree locally which are 'Q' or 'P' but unsure as to which one i should go for
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #13 on: August 28, 2015, 10:14:42 am »
Q or P versions are almost identical. I think the only real difference might be the P version comes from factory with firmware 5238 and the Q version with another a bit older firmware.
I'd buy the cheapest and in better condition and then upgrade it to 5274 modified version. :wink:
Offline Ozzy82
  • -Given: 28
« Reply #14 on: August 28, 2015, 05:33:30 pm »
Great! So i have seen a 'P' version with software v5238 which i am going to buy (hopefully! ) I am also in the process of ordering a new updated CAN gateway from @Eddie_NL - next i will need both those installing i am in Gloucestershire if anyone knows anyone in and around this area? If not, i am willing to travel to Bristol/Wiltshire/even up towards Worcester/Birmingham if needs be! Anyone?!
