Author Topic: supply and fitting new car stereo on MK5 Golf  (Read 8552 times)
Offline Ozzy82
  • -Given: 28
Re: supply and fitting new car stereo on MK5 Golf
« Reply #15 on: August 29, 2015, 05:31:37 pm »
Is something like this ok?
http://pages.ebay.com/link/?nav=item.view&alt=web&id=181832896190&globalID=EBAY-GB
Also, what would i need to buy apart from this unit to get Bluetooth and/or DAB?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #16 on: August 29, 2015, 05:49:45 pm »
To have DAB you need to buy a DAB version. For BT you need to buy a BT kit. Check carsystems.pl or the For Sale section. :wink:
Offline Ozzy82
  • -Given: 28
« Reply #17 on: August 30, 2015, 10:23:11 am »
So i can add Bluetooth to a RNS510 at a later date, but i cant add DAB later, it has to be "DAB on arrival"?" ?
Offline Ozzy82
  • -Given: 28
« Reply #18 on: August 30, 2015, 10:27:49 am »
Also, which one of these would i need, theres so many!? :confused:
http://www.carsystems.pl/bluetooth-kit,c76.html
Offline Pashka
« Reply #19 on: August 30, 2015, 10:35:01 am »
I can supply bluetooth unit for right price, and you could get the loom from Eddie. Will be cheaper and quicker. Cheers.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Ozzy82
  • -Given: 28
« Reply #20 on: August 30, 2015, 10:48:05 am »
Thanks! PM SENT
Offline Ozzy82
  • -Given: 28
« Reply #21 on: August 30, 2015, 03:20:39 pm »
Right guys, i am a little confused at the moment if you can help me please.
I will tell you my current setup first:
Mk5 55plate tdi dsg
Standard midline display
NO mfsw
Rns510 dab getting fitted in 2 days along with new canbus
New BT module (thanks to @Pashka)
BT loom & mic (thanks to @Eddie-NL)
I can get a highline display cluster reasonably cheap in a few days.
Will there be any benefit of the highline cluster to me?
Will it make a difference to how my Bluetooth will work?
How will i get the Bluetooth to work without mfsw?
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #22 on: August 31, 2015, 01:13:30 pm »
Mk5 55plate tdi dsg
NO mfsw
Highline cluster shows the nav directions, track listings and phone book/call info
Bluetooth will still work via the headunit interface
Calls can be placed straight from the headunit using the touchscreen
Nice addition though to have a highline display - and peeps have added the buttons to a non mfsw without too much trouble
I am sure @Eddie-NL can advise accordingly
Offline Ozzy82
  • -Given: 28
« Reply #23 on: August 31, 2015, 01:20:43 pm »
Mk5 55plate tdi dsg
NO mfsw
 thanks for the info! Still in two minds about the highline cluster because i have been told that i need a "Polar FIS BT" kit or something for the calls/phonebook/tracklistings to show properly in the highline display?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #24 on: August 31, 2015, 01:24:32 pm »
If you don't get the Polar BT/Battery module, you can only control your BT module from the RNS/RCD-510 touchscreen. I preferred to have the whole package, so I got the Polar BT module.
Also, the Polar BT/Battery also corrects the battery drainage problem with older Golfs, so you don't need to upgrade the CAN gateway if you just want a newer radio and BT module.
Offline Ozzy82
  • -Given: 28
« Reply #25 on: August 31, 2015, 03:27:47 pm »
Oh man! If i knew the polar unit does that and displays on highline, i probably wouldnt have bought the new canbus! oh well, look on the bright side, saved a but of money for a different mod
Online Andy
« Reply #26 on: August 31, 2015, 06:02:16 pm »
The high line dash is a good upgrade and worth doing
Offline Ozzy82
  • -Given: 28
« Reply #27 on: August 31, 2015, 10:47:20 pm »
Your the 2nd person today who has said that to me! i can just see the notes flying out my wallet as i type this......
