Author Topic: How to: VW OEM Rear View Camera Install  (Read 135078 times)
Offline 182_blue
  • -Receive: 54
Re: How to: VW OEM Rear View Camera Install
« Reply #60 on: July 24, 2010, 07:48:26 am »
The one you put in mine Steve was faultless
Offline Rob GTI
« Reply #61 on: July 24, 2010, 10:50:58 am »
Not had the no picture issue yet on mine.
On a serious note though you do need to use the mirrors as well not just the RVC as you can't see the side of you with the RVC.
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline Rob GTI
« Reply #62 on: July 24, 2010, 03:09:19 pm »
Heres another annoyance with RVC;
Quite often when I get in the car I have to reverse out of somewhere like my drive. If the car hasn't been started for a while you get the VW splash screen on for about 10-15 seconds (even if reverse is engaged). Anyway to speed up this splashscreen so I can see the RV quicker?
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #63 on: July 24, 2010, 03:44:40 pm »
I'll help you get rid off it  :wink: i'll pay postage  :grin:  :P
Over the top mod list ;o)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #64 on: July 24, 2010, 04:00:33 pm »
It seams better with the latest RNSs running the 2720 firmware, have version is yours at?
  • -Receive: 291
« Reply #65 on: July 24, 2010, 04:33:49 pm »
You should be waiting a few seconds before starting the ignition anyway.
Offline Rob GTI
« Reply #66 on: July 25, 2010, 09:46:13 am »
FW is 26XX from this thread:
http://www.mk5golfgti.co.uk/forum/index.php/topic,7154.0.html
and the RNS is an A revision.
Where can I get the 2720 from?
Offline Rob GTI
« Reply #67 on: July 25, 2010, 09:47:56 am »
Why?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #68 on: July 25, 2010, 10:10:02 am »
^^ because of the mice in stealths engine bay.
  • -Receive: 291
« Reply #69 on: July 25, 2010, 10:12:26 am »
 :booty:
Offline jollybob
« Reply #70 on: September 14, 2012, 08:46:35 am »
Hi, hope you can help I have just fitted a rear view boot handle reversing camera in my MK5 golf 1.6 FSI, I have not had it coded yet but will be booking it into VW soon, the problem I have now is I cannot open boot with handle I keep getting code (E234) short to ground can anyone tell me is this due to coding or is there a fault thanks.
Kenny2182
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #71 on: September 14, 2012, 08:51:34 am »
That's not a coding issue, that sounds like the 12v supply isn't connected correctly.
Offline jollybob
« Reply #72 on: September 14, 2012, 09:04:37 am »
Hi Steve, Thanks for your reply, I used your site to fit camera I did this step by step, after making boot harness up I put meter on and double checked it, I put my Ross Tec on car but got (E234) short or ground will check again.
Should the boot open with the handle without coding ?
Kenny2182
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #73 on: September 14, 2012, 09:14:57 am »
As Steve said, the badge needs 12v to operate the release
If you have vag-com then why don't you code it yourself
Cluster and Key coding
Location Great Yarmouth
Offline jollybob
« Reply #74 on: September 14, 2012, 10:25:12 am »
Thanks Steve but my vag com will not let me into long coding it is not supported, coing to check 12v supply.
Kenny2182
