Author Topic: Newsouth steering column pod  (Read 923 times)
Offline Chris92
  • -Given: 33
« on: August 20, 2015, 10:20:55 pm »
After getting another gti mk5 and wanting to fit another boost gauge is it ever possible to get the steering column pod to sit nicely in? My old one never fit good and it annoyed me. Are they ment to have clips built in or something? Any other alternatives pods for the steering column?
Offline JamieBiz
  • Hiss, Pop, Gone...
Re: Newsouth steering column pod
« Reply #1 on: August 21, 2015, 03:35:12 pm »
I didn't know much about the pods available but ended up buying the air vent kit from SWGmotorsport.com
It looked as if the steering column pod might restrict your view of the dial behind slightly??
Put some pics up if you go for another one, i don't think the air vent pod is in a great position on the right hand side of your view so may change it when a better alternative comes up.
Offline Chris92
  • -Given: 33
« Reply #2 on: August 21, 2015, 06:19:22 pm »
For me the air vent pod isn't the best for a boost gauge, oil pressure, oil temp gauge would be much better suited to the vent I think. Have a search on here or google plenty of imagines of the column one, only hides a little of the rev counter and the lower part at that. It's a great pod but I just could never get it to sit/fit properly.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: August 21, 2015, 08:09:23 pm »
I can tell you that my vent kit first allowed the vent to operate...remain open. After shutting that vent once, I was unable to re-open it using the dial underneath and allow air flow again.
