Author Topic: ED30 Forge DV Fitting  (Read 3474 times)
Offline Pauli
  • ED30 Candy White
« on: December 19, 2009, 01:24:37 am »
Im not very technical, bought one today and looked through instructions, instant mind F++K, are they easy to fit or is it a book it in job?
MK6 3dr CW GTi with Dynaudio, 18" Monza Shadows, Winter Pack, Luxury Pack, Rear View Camera, Underseat Drawers. ED30 Gone But NEVER Forgotten.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: ED30 Forge DV Fitting
« Reply #1 on: December 19, 2009, 08:52:44 am »
It's quite simple really, especially on the ed30 because the DV is at the front.  However if you aint confident get someone to help.
Stu...
Offline Pauli
  • ED30 Candy White
« Reply #2 on: December 19, 2009, 09:46:16 am »
I think the instructions I got with it are for a K03 insure, it mensions turbo is at the rear of the motor
Offline GTIjames
« Reply #3 on: December 19, 2009, 10:05:11 am »
had mine fitted recently at jkm was about a 1/2 hr job for them
the instructions are the same for the ko3/k04 but its located at the front of then egine on the ko4
if you have an engine cover on then you will have to remove it to install, have a look at this thread shows where its located
http://www.mk5golfgti.co.uk/forum/index.php?topic=2988.0
you will ntoice the kit comes with two springs if your remapped try putting the yellow spring in
Offline Pauli
  • ED30 Candy White
« Reply #4 on: December 19, 2009, 12:39:31 pm »
forgive my stupidity. Yellow spring goes in the actual DV?
Offline GTIjames
« Reply #5 on: December 19, 2009, 01:07:23 pm »
yeah unscrew it and you will see the spring inside
it needs lubing with the supplied stuff too
its also worth doing this once a year, take it off clean it up and re-lube
Offline singh123
  • Seat Leon Cupra
« Reply #6 on: December 19, 2009, 02:08:45 pm »
Hi Mate here is a link to a video its on a Seat Leon Cupra but i presume the DV is located in the Same place on the ED30
http://leon2passion.com/tutorials-leon-2-f24/montage-pieces-forge-t2762.htm
just scroll down on the first post the vids are at the bottom
Seat Leon Cupra
Offline paulk
« Reply #7 on: December 19, 2009, 09:39:55 pm »
looks a nice product...doesnt look to hard to fit just take your time
Offline Pauli
  • ED30 Candy White
« Reply #8 on: December 20, 2009, 12:10:22 am »
Should there be locktight and lube for the spring included in the kit? Cause I didn't get either
Offline Decked
« Reply #9 on: December 24, 2009, 10:15:07 am »
I must admit, the instructions are crap and a bit of a boggle, but if you setup all the pipes off the car that helped me.
Good luck!
Meteor S3, REVO Stage 2+, APR HPFP, Milltek TBE, Bilstein PSS10's, EVOM's CAI, Forge TB & DV, Pro-alloy IC & LOBA clutch
