Author Topic: Is 5w-40 ok for standard gti engine?  (Read 4129 times)
Offline ReflexRob
« on: August 21, 2015, 11:12:03 pm »
Basically I used to have a BMW that used castrol edge 5w-40 oil and I've got some left over.
I know the manufacturers recommendation is 5w-30 but will it matter? It's vw 502 and 505 grade compliant.
Offline vRSAlex
  • -Receive: 253
Re: Is 5w-40 ok for standard gti engine?
« Reply #1 on: August 21, 2015, 11:19:06 pm »
5w40 is far better for the engines than the 5w30.
I'm not a Castrol fan so would recommend the Millers Nanodrive instead.
Follow AKS tuning on Facebook
Offline ReflexRob
« Reply #2 on: August 21, 2015, 11:22:18 pm »
Thanks,  I will switch to Millers but want to use the castrol up first rather than waste it as long as it doesn't cause harm
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=uuijh17isjcnc7vjfoqfuvfkuo&/topic,19740.0.html
« Reply #3 on: August 21, 2015, 11:30:33 pm »
It will be fine.
Offline Rasco
« Reply #4 on: August 22, 2015, 10:56:23 am »
My manual States vw502 or vw504 for the gti I can't remember which?  but that equates to either 0w-30 or 5w-30, I use the Castrol edge stuff and I have been recommended millers but are there any others that are supposed to be better than the castrol?
Offline flashp
  • -Receive: 65
« Reply #5 on: August 22, 2015, 01:59:15 pm »
And go for an Ester based oil whichever grade you buy. With a fully synthetic oil base they're inherently more stable ay high temps in any grade form.
Gone but not forgotten :-)
Offline PT82
  • -Given: 19
« Reply #6 on: August 22, 2015, 02:21:24 pm »
I use Fuchs Titan Pro Race S 5w 40. Used it for years on all sorts of petrol vehicles. Expensive stuff just like Millers.
