Author Topic: K04 Turbo Oil Feed  (Read 4290 times)
Offline th3_f15t
  • -Receive: 183
Re: K04 Turbo Oil Feed
« Reply #15 on: August 28, 2015, 05:01:45 pm »
Is Item 9 the pipe you have leaking?
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=1&grf=014565412&bf=14565&hgug=145&ug=45&parent_id=2340037
On a closer inspection today, looks like it's the seals at pipe 30 that are to blame. I was cleaning wet looking dirty and found traces of clean oil, considering my engine oil was changed not 1000 miles ago, I'm pretty certain this pipe or the one next to it is to blame, so I shall at least order some new bits from VW to replace it. Is it the same bits as 9, 10 and 11 on this diagram?
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1740&ein=2012&f=729&hauptgr=1234567890&hg=1&grf=010379649&bf=10379&hgug=103&ug=03&parent_id=3676526
« Last Edit: August 28, 2015, 05:03:50 pm by th3_f15t »
