Author Topic: headlight restoration  (Read 1307 times)
Offline Pesky jones
« on: August 24, 2015, 12:38:29 pm »
So  my passenger side headlight is very cloudy. The driver side is in mint condition (slightly odd how they’re different?)
I bought a restorqation kit for about 20 pounds from Halfords to use. I’m not sure if it worked a little bit, but it certainly didn’t restore it.
It was one where you just hand sand it then drill polish it. I’ve heard about the 3m kit, shall I try again with this kit?
Offline xjay1337
  • -Receive: 377
Re: headlight restoration
« Reply #1 on: August 24, 2015, 02:03:32 pm »
Save yourself the money
Buy 800 grit
1500 grit
2000
2500
work 800 until whole headlight is cloudy and even when dry.
then go up through 1500, 2000 then 2500.
then use a machine polisher with a correction compound and a hard pad then a softer pad with a refinement/finishing polish.
protect with a decent sealant.
done.
Offline Pesky jones
« Reply #2 on: August 24, 2015, 02:06:28 pm »
Save yourself the money...then use a machine polisher...
I don't have one, will it save me money? the kit is only 20£
Offline xjay1337
  • -Receive: 377
« Reply #3 on: August 24, 2015, 02:11:16 pm »
borrrow one  :happy2: :happy2:
Offline tobievans
« Reply #4 on: August 24, 2015, 08:12:53 pm »
How long did it take to wet and dry like that?
Offline Rasco
« Reply #5 on: August 24, 2015, 10:58:44 pm »
Ok I need to do this too, just need advice on what finishing compound and sealant to use at the end?
Offline xjay1337
  • -Receive: 377
« Reply #6 on: August 25, 2015, 11:57:35 am »
I can do them about 45 minutes to 1 hour per side if I really go hell for leather.
Offline Beej
« Reply #7 on: August 25, 2015, 08:22:33 pm »
mine are only slightly starting to cloud up, but i am a little weary about sanding them, but i think i would rather that than buy a kit that didn't really do what i wanted.....so i will be sanding, polishing and sealing!
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #8 on: August 25, 2015, 09:31:01 pm »
I used the 3M kit on my headlights about 3 weeks ago and got good results, See my thread in the members rides section.  :happy2:
