Author Topic: Water in rear light  (Read 1205 times)
Offline Rholtby
  • Rholtby - 2008 Edition 30
Water in rear light
« on: August 25, 2015, 10:39:54 am »
So when I bought the car the rear light needed replacing so I bought a new one and it's been fine until recently. Firstly I've noticed fog inside the light on numerous occasions but now there's a whole load of water gathered inside the light. I've taken the light out and going to let it drain off and hopefully dry out.
Any ideas why this is happening?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Water in rear light
« Reply #1 on: August 25, 2015, 11:27:36 am »
Is the new one you bought oem?
Do you powerhose the light when you're washing the car?
What's happening regardless is that the rubber seal around the light is letting water in. If you can dry out the light properly, put clear silicone around the entire seal and wipe away excess then refit it.
Offline guyrocks
  • -Given: 17
« Reply #2 on: August 25, 2015, 11:51:52 am »
Yer I second this my m8 had the same problem he put some on and its been fine since. Stay away from direct jet washing tho
Offline Jarre
« Reply #3 on: August 25, 2015, 11:08:15 pm »
You need to ensure that when you put it back the screw is done tight. Don't over tighten it and break your light obviously,  but that screw creates the seal for the light.
Sent from my SM-G920F using Tapatalk
Candy White ED30 :)
Offline Rholtby
« Reply #4 on: September 04, 2015, 01:47:33 pm »
Thanks guys. I've had the light replaced as it was under warranty. I'll see how this one goes but might seal it with silicone anyway. Thanks again
Offline Rholtby
« Reply #5 on: September 21, 2015, 12:11:19 pm »
Thanks for all your help guys, I got my replacement light which was still fogging up so a night in the airing cupboard then some silicone sealant and there's been no dramas three weeks later.
Thanks again
