Author Topic: Fitting W and Y Tyre ratings to the same vechile  (Read 776 times)
Offline Rob1
  • -Given: 40
  • -Receive: 24
« on: August 25, 2015, 03:37:38 pm »
Hi all as per the title, my car currently has Y rating tyres all round but considering purchasing a set of new W rating tyres for the front, would this pose a problem or is it a safe to fit different rated tyres. Naturally i dont intend to go over the speed ratings for each respective tyres
Thanks Rob1
Black Ed30
Offline Rasco
Re: Fitting W and Y Tyre ratings to the same vechile
« Reply #1 on: August 25, 2015, 03:49:36 pm »
don't mix, I believe it's illegal to have different speed rated tyres on the same car? not sure could be total b*llocks.....
« Reply #2 on: August 25, 2015, 04:05:16 pm »
On yours Rob if your still in the tdi it's fine as long as the load number is the same or higher of which is the same if you put am odd tyre on
Offline dronners
« Reply #3 on: August 25, 2015, 11:35:22 pm »
long as its the same on each axle it will likely be fine
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #4 on: August 26, 2015, 06:45:14 am »
Ok cheers guys I bought the Y rated tyre
Black Ed30
