Author Topic: help Engine light on!!!  (Read 1509 times)
Offline Washout
« on: August 26, 2015, 06:46:56 pm »
Great driving to shops and engine light comes on, back home on the scanner and have some fault codes. Please can someone advise me on these. Eternally grateful. Sorry mods if in wrong section.
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH14---    Serial number: VWZ7Z0F8109317
   Coding: 0403000318070160
   Shop #: WSC 00651 210 89735
   VCID: 2D577FEFB493EC7600B-8078
2 Faults Found:
012599 - Intake Manifold Runner Control
               P3137 - 001 - Basic Setting not Completed - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 109497 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 58.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.319 V
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 002 - Low - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 109497 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 58.0°C
                    Temperature: 42.0°C
                    Voltage: 12.319 V
Readiness: 0000 0000
Re: help Engine light on!!!
« Reply #1 on: August 26, 2015, 07:39:01 pm »
You could first try a basic setting for the intake manifold motor in vcds but in all honesty I think you'll be needing to renew the motor.
Prerequisites:
 Ignition ON
 Engine OFF
 System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
 Group 142
[Go!]
 Activate the Basic Setting.
[ON/OFF/Next]
 Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch Ignition OFF for at least 60 seconds.
Offline Washout
« Reply #2 on: August 26, 2015, 07:44:52 pm »
Prerequisites:
 Ignition ON
 Engine OFF
[Select]
[01 - Engine]
 Group 142
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Right I see, at we looking at mega money etc. will it be safe to drive I'll need to run it to vw tomorrow after work. Not attempting it myself as its a bit of a pita.
« Reply #3 on: August 26, 2015, 08:32:07 pm »
iirc a new motor costs around £180 from VW.
The car should be ok without it functioning as it's needed for cold start running. Indeed in some highly modified cars the intake flaps are sometimes replaced altogether to attain more hp...
Offline Washout
« Reply #4 on: August 26, 2015, 08:37:37 pm »
Thanks for this matey apreciate your help. It has been a bit poor starting recently a bit spluttery. When I was driving it had a loss of power which was almost instantly gone, parked up and light came on. I'll run it in to vw tomorrow.
Offline Washout
« Reply #5 on: August 26, 2015, 09:25:48 pm »
Just been having a look and from what I can tell replacing the motor is a fairly straight forward job, I have found a couple of diy s but these are outdated so no pics, could anyone point me in the direction of a decent one. Cheers
« Reply #6 on: August 26, 2015, 10:30:37 pm »
This diy is not for a golf but the install is the same i.e. a 2.0l tfsi engine.
http://www.audizine.com/forum/showthread.php/306032-DIY-Intake-Flap-Motor-Replacement
