Author Topic: Help With Codes Please  (Read 2263 times)
Offline Dobbsy
« on: August 27, 2015, 03:07:43 pm »
Hi Guys wife mk5 Gti came up with the engine check light,
Runs a bit lumpy and seems to be breathing through the oil dip stick.
Got a screen shot of the snapon scanner if anyone could help ?
https://www.dropbox.com/s/vccy3mou1m0o6x2/Photo%2027-08-2015%2014%2017%2057.jpg?dl=0
Craig
Offline Paradox1
  • -Given: 41
Re: Help With Codes Please
« Reply #1 on: August 27, 2015, 03:24:45 pm »
Its an air leak mate,  check your intake clamps are done up tight. could be a faulty DV or even PCV valve
Offline Dobbsy
« Reply #2 on: August 27, 2015, 03:54:35 pm »
Just checked and its the original PCV so just ordered one from VW will borrow my m8's Vagcom and double check the the code dosnt reappear .
DV Next if not, I put a smoke tester on it and its only leaking out of the airbox.
Offline Dobbsy
« Reply #3 on: August 27, 2015, 04:00:51 pm »
where can I get a Diverter Valve from if anyone can recommend a uk company think revision D is what I need ?
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #4 on: August 27, 2015, 04:13:21 pm »
Mass consensus is that Revision G is the one to get.
The Rev D is a piston valve, and while more 'reliable' by design, they can still seep pressure.
Rev G is the latest and greatest diaphram valve. Holds boost nicely and works like a dream. I had a new pcv, cam follower and Rev G fitted a couple of months ago and it made a massive difference.
Since then I've had a remap and it boosts consistently well, so I'm sure the Rev G was a good choice.
Think I have a p/n somewhere..
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #5 on: August 27, 2015, 04:15:08 pm »
Here you go. VW or TPS.
06F 145 710 G
Offline Dobbsy
« Reply #6 on: August 27, 2015, 04:31:46 pm »
Thanks buddy going VW on saturday to collect the PCV so will order that at the same time.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #7 on: August 27, 2015, 05:18:25 pm »
No worries. Worth doing the follower while you're at it if it hasn't been done recently too.
The dv, pcv and cam follower seem to be 'the usual suspects' in many cases. And they're not expensive parts, or a big job to fit, so it's worth getting the lot done as much as it's worth doing oil & filters etc.
Hope it sorts it for you anyway.
Offline Dobbsy
« Reply #8 on: August 28, 2015, 10:52:09 am »
Cam follower ?
My m8 did a full cambelt kit on it earlier in the year, would that have been included
Craig
Offline Paradox1
  • -Given: 41
« Reply #9 on: August 28, 2015, 10:58:29 am »
not likely. its in the fuel pump on the right side of the engine.
about 30quid and take 10 mins to replace. well worth doing though
Offline Dobbsy
« Reply #10 on: August 28, 2015, 11:29:32 am »
Thanks for the info will see if I can hunt one down anyone got a link to what I need ?
Thanks Guys  :driver:
Is this it ? http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/40-ENGINE-Camshaft_Sensor_Replacement/40-ENGINE-Camshaft_Sensor_Replacement.htm
« Last Edit: August 28, 2015, 11:33:22 am by Dobbsy »
Offline Paradox1
  • -Given: 41
« Reply #11 on: August 28, 2015, 12:26:02 pm »
nah this is it mate.
cheap but well worth it. engine will fail if it goes wrong
Offline Dobbsy
« Reply #12 on: August 28, 2015, 12:46:28 pm »
cheers for that, ive just ordered a genuine one. :happy2: :happy2: :happy2: :happy2:
