Author Topic: Noise after fitting suspension?  (Read 1252 times)
Offline Stevepd
  • -Given: 49
« on: August 27, 2015, 06:23:25 pm »
So I've just replaced my standard leaking shocks for a standard replacement, job went well with no problems. I've done 217 miles this morning since fitting and the the knocking noise started from the OSF, enough to hear it in the cabin on the move. Doing some diagnosis on they way home - around 60 and lift off the throttle to glide and the noise appears (rotational knocking). If I apply the throttle (any amount) the noise disappears. Again coasting and letting the speed reduce I applied the handbrake and the noise stays, so the front brake does have an influence. I'll try tomorrow in the car park where I can do a full lock turn.
Any ideas?
« Last Edit: August 27, 2015, 08:31:50 pm by Stevepd »
Standard 5 Door Shadow blue.
Offline DANBOY66
  • -Given: 41
Re: Noise after fitting suspension?
« Reply #1 on: August 27, 2015, 06:40:37 pm »
first thing i would do is jack it up and check all the bolts are tight  :happy2:
Dan..
Offline Paradox1
  • -Given: 41
« Reply #2 on: August 28, 2015, 11:23:59 am »
did you change the top mounts?
Offline Stevepd
  • -Given: 49
« Reply #3 on: August 28, 2015, 05:29:14 pm »
Yes all the bolts are tight and zero movement on any links.
I didn't change the top mounts as they were spot on.
I'm convinced it's drive train related, rotational noise just like you'd identify a stone in the tread........
