Author Topic: Forge PCV Valve  (Read 2293 times)
Offline Isaac McElroy
Forge PCV Valve
« on: August 28, 2015, 08:12:37 pm »
Hi all, I've suspect My pcv valve has gone on me. Car is suffering from all the major symptoms.
I see on gumtree a forge PCV valve for sale only a couple of miles from where I live. What i want to know is, any body running one, what's their opinion on it and is £50 reasonable.
My knowledge is somewhat limited so any advice or guidance is greatly appreciated.
Thanks..
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Forge PCV Valve
« Reply #1 on: August 28, 2015, 09:59:06 pm »
Haven't used the Forge, only the BSH, PCV delete plate. They work fine and helpful if experiencing PCV failure.
With that said...the OEM PCV is preferred for the motor. I just removed my PCV delete plate and reinstalled my OEM PCV because it had became suspect for the destruction of my valve cover.
I would suggest continue using the OEM PCV unless you have repeated PCV failure occurring less than every 80k miles.
Offline th3_f15t
  • -Receive: 183
Re: Forge PCV Valve
« Reply #2 on: August 29, 2015, 10:43:03 am »
Again, OE PCV latest revision is the best option, but if you want to go all out then a decent catch can may be the way ahead.
Re: Forge PCV Valve
« Reply #3 on: August 29, 2015, 10:46:06 am »
Thanks, so the Forge delete is really a unnecessary expensive if the pcv valve failure is not a reoccurring problem?
I'll just stick to the OEM part then. Thanks mate
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
Re: Forge PCV Valve
« Reply #4 on: August 30, 2015, 04:15:02 pm »
Correct...keep running the OEM bit unless PCV fails often.
