September 10, 2024, 12:22:46 am
All Things Mk5
Cosmetic/Interior Modifications
Std gti ride height
Topic: Std gti ride height (Read 3153 times)
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
Std gti ride height
August 29, 2015, 10:36:42 am »
I am trying to work out if my gti is already lowered or not.
Who ever is on the std suspension pls can you tell me the height from arch to tyre
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
Re: Std gti ride height
Reply #1 on:
August 29, 2015, 10:17:28 pm »
Took a pic of mine
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
Reply #2 on:
August 31, 2015, 08:14:02 am »
Anyone?
Ryan_Gti06
Taking part
-Given: 5
-Receive: 2
Reply #3 on:
September 01, 2015, 10:26:34 am »
Doesn't look lower to me mate, maybe the dark coloured wheels just gib the illusion? Can't you see the springs? Should be able to see if they're VW or not
rich83
Just look at my post count
-Given: 165
-Receive: 801
My Ride:
Reply #4 on:
September 01, 2015, 10:31:54 am »
Have a look at the springs. If they are black and have 3 coloured dots on them, then they are OEM. Aftermarket ones are usually red or blue.
https://www.justgiving.com/thenational3peaks
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
Reply #5 on:
September 01, 2015, 06:47:24 pm »
They are black. Just trying to work out my the ride is a bit rough. My mk4 gti wasn't that bad
AJP
Global Moderator
-Given: 392
-Receive: 316
Reply #6 on:
September 01, 2015, 08:38:36 pm »
Quote from: Vwgtiking on September 01, 2015, 06:47:24 pm
Mk4 suspension was much softer than the Mk5. And that does look 20-30mm lower than standard to me.
Measure from floor to top of arch, aligning the tape/ruler with the centre of the wheel.
AJP
Global Moderator
-Given: 392
-Receive: 316
Reply #7 on:
September 01, 2015, 08:40:58 pm »
This is mine on H&R 30mm when I was on Monzas.
GTIEagles
Won't Shut up.
-Given: 10
-Receive: 22
Reply #8 on:
September 02, 2015, 07:21:39 am »
I would say that's standard, it's about the same as mine which is standard.
All Things Mk5
Std gti ride height
