Author Topic: Removing Wing mirror unit  (Read 1694 times)
Offline Callum45
« on: August 29, 2015, 03:28:49 pm »
Hi guys wanting to remove the complete wing mirror unit
What is the best way to go about it? Remove the inside door card? How do i remove the speaker which sits on top off the door card?
Any guides with pictures out there? Thanks
Offline bbfb10
Re: Removing Wing mirror unit
« Reply #1 on: August 29, 2015, 04:13:50 pm »
I did this the other day;
Inner door trim off, disconnect all wires.
Speaker trim came off easilly enough with a trim removal tool.
3 bolts to undo wing mirror unit, one is behind a black plastic cover.
Wing mirror should come off easilly.
Getting it back on is a PITA!
https://m.youtube.com/watch?v=EkcIlSys6V4
Full VCDS Hex + Can.
Offline Callum45
« Reply #2 on: August 30, 2015, 09:12:17 am »
Thanks mate, seems fairly easy watching that video.
What bit was a PITA to put back on?
Offline bbfb10
« Reply #3 on: August 30, 2015, 09:14:10 am »
The trim around the door frame/window wasnt much fun.
