Author Topic: Rear caliper sticking.  (Read 15719 times)
Offline lambera
  • Edition 30 No 1197
« on: August 29, 2015, 06:36:48 pm »
So I was told today after my mot that my rear passenger caliper is sticking. This would probably explain the annoying squeaking I have been getting when lightly braking. Is a new caliper required or can a service kit be bought?
Tornado Red Edition 30 No 1197
Offline david25
  • -Given: 19
Re: Rear caliper sticking.
« Reply #1 on: August 30, 2015, 10:09:58 am »
I had this last year and recommend you budget for a new caliper.
Offline lambera
« Reply #2 on: August 30, 2015, 10:33:00 am »
I found a rebuild kit online for £25 which has all new seals and so on. Did the new caliper fix the problem?
Offline Matthewsimone
  • -Receive: 39
« Reply #3 on: August 30, 2015, 12:15:16 pm »
Recently replaced oneof my rear calipers due to sticking etc
Genuine painted red caliper on ebay around £80
Not worth messing about with old one to be honest plus my mpg increased by quite alot once replaced due to the drag from that wheel  :happy2:
Offline lambera
« Reply #4 on: September 01, 2015, 03:05:49 pm »
Does anyone know if the rebuild kits will fix the problem.
Offline AIR_CHILLED
« Reply #5 on: September 01, 2015, 10:10:55 pm »
Or are your sliding pins bent?
Offline lambera
« Reply #6 on: September 04, 2015, 10:00:06 am »
I don't think so, just got told on the mot it was sticking.
Offline xjay1337
  • -Receive: 377
« Reply #7 on: September 04, 2015, 10:04:43 am »
Just buy a used or new caliper on Ebay.
Pretty common. Not worth repairing it, usually the slider pins get completely buggered.
Offline RC84
« Reply #8 on: September 04, 2015, 01:29:09 pm »
Got the same issue with mine at the moment and I've been searching all morning for a reasonable replacement. Any links to EBay calipers etc? Or genuine ones at £80 on eBay?
Called my local TPS this morning and was quoted £190.54 for a new genuine rear caliper. I very nearly burst out laughing :grin:
Euro car parts do 2 types of non genuine calipers. "Pagid" rear caliper (would need powdercoated) at £94.80 and "TRW" (red powdercoated) at £110.40.
Am I best buying genuine or settling for non oem? Also, is it best to replace both rears at the same time to save another headache?
Offline AIR_CHILLED
« Reply #9 on: September 04, 2015, 03:42:47 pm »
Hi, oem calipers were originally made by TRW so that's a good choice especially in red.
If your competent to rebuild your own calipers buy a seal kit from Brake International as a secondhand one could easily seize again in a few years. (Rears are easy to rebuild as you can wind the piston out)
Don't forget Touran calipers are the same and cost £20 second hand worth a thought.
Also 2k caddy calipers are also a direct replacement on 286 / 282mm carriers. This would be an upgrade as they have larger Pistons (search rear NQSBBK)
I mentioned about sticking slider pins as a friend had this problem on a VRS for the MOT, he ended up buying a new caliper and painted it green only to find out the pin was bent causing the rear to bind.
Mike.
Offline RC84
« Reply #10 on: September 04, 2015, 05:59:50 pm »
Mike.
That's great Mike, thanks a lot for that. I've had the wheel off and had a good look round about and it doesn't look like any pins or metal is bent in there but I did notice it's starting to grind away the pad a bit now. The calipers are also stamped TRW as you say.
I've been quoted £244+vat for 2 rears supplied and fitted. That's a vw specialist. Fair deal?
Offline AIR_CHILLED
« Reply #11 on: September 04, 2015, 06:05:51 pm »
Mike.
Seems like a fair price considering you found them for £110 each and you won't have to get your hands dirty!
Offline jaffa
  • -Receive: 44
« Reply #12 on: September 04, 2015, 06:09:26 pm »
I got a new TWR branded r32 rear caliper from www.brakeparts.co.uk for around £80 so worth a look on there
Offline RC84
« Reply #13 on: September 04, 2015, 08:06:59 pm »
Thanks Mike for the advice, much appreciated. And thanks for the link Jaffa I'll have a look on there too, cheers guys :drinking:
