Author Topic: Whats needed to fit mk6 gti steering wheel to mk5  (Read 10924 times)
Offline hogan
« on: September 01, 2015, 12:38:04 am »
Gents,
If anyone who has done this could provide some details.
Besides for the steering wheel and airbag, what else is needed to make this work?
Is the steering module and clock spring from mk6 required?
Does coding need to be done also?
Part numbers would be great.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Whats needed to fit mk6 gti steering wheel to mk5
« Reply #1 on: September 01, 2015, 04:17:31 am »
Type 2 slip ring
Steering control module CH version
Rev G cruise control stalk (if fitted already)
Sent from my D6603 using Tapatalk
Offline Pashka
« Reply #2 on: September 01, 2015, 06:15:44 am »
Type 2 slip ring
Stalk can be redone to match G version, just need to solder two yellow wires into 1, I think to pin 11.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline JustSho
« Reply #3 on: September 05, 2015, 02:04:47 pm »
Am I correct in saying only 7/12 of the MFSW buttons actually work?
Im also looking to get this mod so will be keeping an eye on this one!
Offline patpong_pete
« Reply #4 on: September 05, 2015, 03:30:18 pm »
Type 2 slip ring
Has anyone done this modifacation on the cuise stalk ?
Eddie NL good sir
do you have any more knowledge on this kind sir
thanks in advance pete
Offline bluo
« Reply #5 on: September 11, 2015, 10:55:43 pm »
I've just done mine. Parts required below, I did t have to change my slipring as I already had a Rev C fitted and also had the CC fitted.
Coding is required and not all the buttons work. Left side, left and right don't do anything. Maybe o haven't coded it correctly but it's not a big deal (would love to have all buttons working if anyone knows how).
Slipring
1k0 959 653 C
Control Module
1k0 953 549 CH
Cruise control
1k0 953 513 G
Offline GTIite
  • Build it.. don't buy it!!
I have ETKA and ELSA - Happy to help if anyone needs anything. Instagram - @f11tvw
Rotiform VCE's : US Spec Rear Bumper : Colour Coded Side Skirts : US Grill : De-Wipered : Revo Stage 2+ Map : Revo Intake : Revo throttle pipe : THS Intercooler : K04 Conversion : Milltek Cat Back + Pipwerx Decat : Sachs Stage 3 Organic clutch + Single mass flywheel : Quaife ATB Differential : S3 Brakes + Vagbremtechnic discs : Full SuperPro Bushes : SuperPro ARB
