Author Topic: 04 1.9TDI Hot Start?  (Read 2549 times)
Offline Betty02
    • iBett
« on: September 01, 2015, 02:37:29 pm »
Evening all,
Got another TDI yesterday, so 2 GTi's and now 2 TDI's! This one when starting cold has a massive judder when the engine does start, it doesnt struggle as such but huge judder sort of thing? Sounds like engine is coming off the mounts lol, then when warm it takes a while to start? 7-10seconds ish? Gets to temp pretty quick also?
Any suggestions?
ADMIN NOTICE: Please do not use the site for advertising!
Offline xjay1337
  • -Receive: 377
Re: 04 1.9TDI Hot Start?
« Reply #1 on: September 01, 2015, 02:59:43 pm »
Common issue
Replace starter and battery.
Remap to resolve hot start issue.
Offline Betty02
    • iBett
« Reply #2 on: September 01, 2015, 04:22:01 pm »
Is it just the starter then? Not the temp sensor or anything? Will the cause the car to warm up very quickly?
Offline Pashka
« Reply #3 on: September 09, 2015, 09:04:02 am »
it's starter problem, get your starter rebuild or change to another one, but the easiest way is to get ecu program corrected. On default, on low RPM's, injectors don't inject fuel.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
jdoc_18
« Reply #4 on: February 25, 2018, 07:57:30 pm »
Sorry to bump this - Got a Mk5 GT TDI and it starts perfectly when cold, but takes while of turning the engine before it catches when its warm.
You mention a remap being the easiest/cheapest solution - exactly what would I need to ask for please and is this dealership thing or any reputable garage?
Thanks in advance
