Author Topic: Radiator fans help please!!! bump with video  (Read 3804 times)
Offline Daled0111
  • -Given: 26
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,95386.0.html
« on: September 03, 2015, 06:41:46 pm »
Help please
Has anyone got any  ideas, both of my fans turn on full pelt some times when I start the car when I turn it off they stay on and can't get them to go off but the only way to turn them off is remove fuse and refit fuse then they stay off,
I have spent loads on parts but luckily I am a mechanic so fit everything at work.
I HAVE changed- both relays, both coolant temp sensors, battery, both fans but problem still there any idears
Really need to get it sorted been doing it for couple of months now and has cost me 250+ on parts already
« Last Edit: March 22, 2016, 11:13:11 pm by Daled0111 »
Offline bingbunny
Re: Radiator fans help please!!!
« Reply #1 on: September 03, 2015, 07:07:29 pm »
Im not a fan of radiators, but I can say that my old golf MK5 GTTDI used to do this. I took it into VW and they did something with the ECU.
Offline Blackgtiman
« Reply #2 on: September 03, 2015, 07:24:27 pm »
have you connected to vagcom to check for faults?
Offline Daled0111
  • -Given: 26
« Reply #3 on: September 03, 2015, 07:42:49 pm »
How much did VW charge
Also yes I have got a mate with vagcom and nothin came up
Offline bingbunny
« Reply #4 on: September 03, 2015, 10:12:18 pm »
It was done under warrantee but they appeared to know what the problem was even though I was one of the first in the country to have one with the miles I had done. Might be work calling them and asking if they know a common fault.
Offline Craigh1983
    • Leicester Wedding Photographers
« Reply #5 on: September 04, 2015, 03:03:25 pm »
I had the exact same problem with my fans but fortunately replacing the fans fixed it. So know how frustrating it is. I had a bit of plastic from my main fan missing so when mine used to go full pelt the vibrating sound was extremely loud and I could see everyone looking! I had to keep turning the engine off and taking the key out for mine to stop and then restart the car. Used to be a right pain when stuck in rush hour traffic!
Hope you get it sorted!
Offline Daled0111
  • -Given: 26
« Reply #6 on: October 11, 2015, 04:47:20 pm »
still doing it but have noticed that when they are on full and i turn the ignition on and off a few times quickly they turn off
Offline Daled0111
  • -Given: 26
« Reply #7 on: February 27, 2016, 10:09:38 pm »
bump need help still doing it
Offline MS1
« Reply #8 on: February 28, 2016, 08:55:51 am »
Wish I could help mate. Had the same problem recently. Fans came on two hours after car was driven. Ended up being faulty coolant sensors. Never heard a noise like it, with both of them going full chat.
R-Tech Map/ Longlife TBE w/200 cell Sports Cat / ITG Maxogen G60 / Loba HPFP / Forge Twin FMIC / Forge TB Hose / R8 Coilpacks / Neuspeed Power Pulley / EBC D&G Front & Rear Discs / EBC Yellowstuff Pads / BSH PCV Kit / Super-Pro Front & Rear / W.A.L.K / APR Torque Arm / 034Motorsport Density Line Engine Mounts / Vibratechnics Subframe Mount / Vibratechnics Dogbone Bush
284bhp / 307lbft
Offline Softishman
« Reply #9 on: February 28, 2016, 08:56:02 am »
If you disconnect both fans with the connector on the left lower side of the radiator and clean it,did it for me! Else you need to change the big fan...
Offline Daled0111
  • -Given: 26
« Reply #10 on: February 28, 2016, 10:03:36 am »
i have changed
-big fan
-small fan
-both coolant temp sensors
-battery
-coolant fan relay
and when i scan the car with my vagcom it does not come up with any faults
Offline MS1
« Reply #11 on: February 28, 2016, 11:49:01 am »
So... Problem solved??
284bhp / 307lbft
Offline Softishman
« Reply #12 on: February 28, 2016, 03:05:00 pm »
Aouch.... Clean the connector and check wiring to fans from fuse...
Offline Daled0111
  • -Given: 26
« Reply #13 on: February 28, 2016, 04:00:04 pm »
problem still there have cleaned connector
Offline Daled0111
  • -Given: 26
« Reply #14 on: March 22, 2016, 11:12:42 pm »
bump this time with video
please help anyone its really annoying
in the video the fans are on then go off then after a short pause they go on again.
