Author Topic: Pcv help  (Read 754 times)
Offline Jay_ed30
Pcv help
« on: September 05, 2015, 10:50:28 am »
Morning all I have just fitted a new pcv to my edition 30 now when I start the car it just revs to about 3500 revs with the new valve any ideas?
Offline Jay_ed30
Re: Pcv help
« Reply #1 on: September 05, 2015, 11:02:14 am »
Fit the original valve that can be blown through from the intake side and it ticks over fine?
Offline Jay_ed30
Re: Pcv help
« Reply #2 on: September 05, 2015, 12:36:33 pm »
Basically with the new valve I have fitted from my local dealer when first started it hunts a little like it would if you removed the oil cap then it just revs on its own. I have removed the valve several times and refitted but it's still the same? I've put my old pcv on and it idles normal. The reason for changing was I could blow through the valve from the intake side.
Offline Jay_ed30
Re: Pcv help
« Reply #3 on: September 05, 2015, 04:28:39 pm »
Resolved this problem now I believe as they stealers have given me a revision p valve which I believe is wrong and I need a revision n which is what I ordered
