Author Topic: Changed the dash board now the car won't even turn over?!?!?  (Read 1854 times)
Offline Samboy
« on: September 06, 2015, 05:29:15 pm »
So I got a new dashboard, which sounds odd but it's alcantara!
I disconnected the battery as I knew I was taking the steering wheel off with airbag and everything, the controls around the wheel were off. Got the new dash all in put everything back exactly as it was, put the battery in, turned the key and nothing at all!! No clicks nothing!
All the lights work inside and outside, the stereo all works but that's no good!!
Anyone know what I could have done?????
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Changed the dash board now the car won't even turn over?!?!?
« Reply #1 on: September 09, 2015, 12:54:58 pm »
Maybe something isn't well connected.  :confused:
The starter engine/cluster should make some noise. Well, my Ed. 30 when needed a new battery made a ticking noise when I tried to start it. It seemed like the ticking noise came from the cluster and not from the engine bay...
Offline xjay1337
  • -Receive: 377
« Reply #2 on: September 09, 2015, 02:19:35 pm »
Obviously something isn't working
there's a fuse for the dashboard cluster. check that. if that's failed car won't start.
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
« Reply #3 on: September 09, 2015, 03:29:07 pm »
make sure the plugs on all the modules on column are home fully
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline Samboy
Re: URGENT HELP!!! Changed the dash board now the car won't even turn over?!?!?
« Reply #4 on: September 15, 2015, 09:50:47 pm »
just been at this again tonight, checked all connections and everthings back right all the pins in connections line up and everthing!!
the ignition barrel does click but nothing at all happens!
if theres a fuse or anything, does anyone know what one??
would plugging a vcds help? has anyone got one near Cambridge if it would
gotta be out the work shop im in in a week
Offline doylebros
« Reply #5 on: September 17, 2015, 04:43:49 pm »
As a starting point do you know if the battery is up for the job of starting - what features work at key position two?
Offline Samboy
« Reply #6 on: September 17, 2015, 05:13:22 pm »
Someone just said that to me! I've just assumed that coz it worked before the dash come out it was fine.
The lights turn on, stereo comes on..that's about it
Offline Samboy
« Reply #7 on: September 17, 2015, 05:24:56 pm »
And thinking about it the stereo goes off after about 3 mins if you leave it which it never used to, and I've been trying to wire a sub up which the amp comes on but nothing out the sub although it all works in a different car
