Author Topic: My driver side mirror  (Read 568 times)
Offline Riggs
« on: September 08, 2015, 09:52:19 pm »
Hi all,
I have not long got my MK5 GTI, the mirrors on it have the indicators but i dont think they have the puddle lights? was this an option that I dont have?
I have also noticed that the mirror moves fine with the switch to adjust the angle of the glass, but the indicator does not work on the driver side, and i have also noticed that when I put the switch to the heated bit, the passenger one clears of condensation in minutes where as the driver side does not... so am i right in thinking that this indicator and no heat problem may be linked and the wires might have a problem?
Cheers all!
Brian
Offline bbfb10
Re: My driver side mirror
« Reply #1 on: September 09, 2015, 05:44:54 pm »
Puddle lights was an option along with power folding function. If the indicator light doesnt work it could simply need replacing, the two problems together does suggest either a wiring or control module issue. Take the mirror glass off and check the two heating wires are connected to the back of the unit.
Full VCDS Hex + Can.
