Author Topic: OPS via canbus  (Read 3096 times)
Offline Ditto
OPS via canbus
« on: September 14, 2015, 01:36:44 pm »
Hey guys
Do you know if OPS is available via the Mk5 canbus as it was in the mk6? I.e. if I were to fit a radio with the radar display, would this work?
It's a 2007 model, which i believe has a different canbus version?
Matt
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: OPS via canbus
« Reply #1 on: September 14, 2015, 02:20:13 pm »
At least since the L revision CAN Gateways are compatible with OPS sensors. You'll need to replace all the sensors and fit a new sensors ECU of the mk6 generation. Carsystems.pl sells the full kit (rear, front, front and rear).
Offline Ditto
Re: OPS via canbus
« Reply #2 on: September 14, 2015, 03:43:24 pm »
Thanks Shoduchi
So as I suspected the standard sensors on the mk5 do not feedback to the canbus? Only the newer versions do?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: OPS via canbus
« Reply #3 on: September 14, 2015, 04:07:28 pm »
I think the Can Bus is the least of your problems. The mk5 sensors shouldn't have the technology required to work with the OPS ECU. You need to upgrade the whole system. I have both my Golfs with OPS front and rear, by the way. :wink:
Offline Pashka
Re: OPS via canbus
« Reply #4 on: September 14, 2015, 05:20:00 pm »
who said so? It's a lie. OEM parctronics works fine with OPS, only "OEM" cobra ones, don't work.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: OPS via canbus
« Reply #5 on: September 14, 2015, 05:37:31 pm »
Are you saying that mk5 sensors work just as fine as the mk6's sensors with the OPS ECU that show the graphics in the RNS/RCD-510? The OEM sensors are Bosch and their shape is different. IIRC connectors and loom are different.
I'm just selling the story as I was told by my friend who fitted the sensors. :confused:
Offline Ditto
Re: OPS via canbus
« Reply #6 on: September 14, 2015, 07:20:40 pm »
Thanks for the info guys. To clarify, the unit inside the boot is Bosch and the sensors look as follows
Offline Lyons
  • -Given: 18
Re: OPS via canbus
« Reply #7 on: September 14, 2015, 07:45:22 pm »
I got the rear OPS kit from China for £85 odd. I have the sensors fitted and painted but haven't had a chance to get the wiring installed yet. Everything is there though.
Offline Ditto
Re: OPS via canbus
« Reply #8 on: September 14, 2015, 07:52:18 pm »
Think the answer can be found here, looks like as Shoduchi suggested only the OEM mk6 Valeo ones will work; http://www.r32oc.com/topic/22301-optical-rear-park/page__st__30
Offline SI-R32
  • -Receive: 125
Re: OPS via canbus
« Reply #9 on: September 14, 2015, 08:07:25 pm »
potentially this may be true as its the parking ecu that sends the signal to the can bus for the stereo to display.
so vw may have introduced a parking ecu made by bosch that's compatible with old sensors but ops connects to the powertrain can bus and not the convenience can bus which the mk5 has as standard.
its just sometimes easier to fit the Valeo sets which will work no problem for people without sensors
with regard to original post, 1 your oem wiring is connected to wrong can bus for ops
2 I don't know of a bosch parking ecu that supports ops
3 changing to valeo sensors isn't a 5 min job as your sensor holders being OEM will be plastic glued to the bumper not necessarily stuck with double sided foam like they should be, the bosch holders don't hold the valeo sensors you'll have to change them.
quick cost for the job say 200 with the kit
Offline Ditto
Re: OPS via canbus
« Reply #10 on: September 14, 2015, 08:44:37 pm »
Hi Si
Thanks for the detailed response  :happy2:
Sounds a lot of work to retrofit! Was only interested as many of the aftermarket stereos boast this functionality along with other features. As you say, this must be down to the difference in canbus on the 5 vs 6.
