Author Topic: Splutter under load  (Read 1284 times)
Offline Northy1985
  • Instagram o_n02thy
Splutter under load
« on: September 18, 2015, 05:36:29 pm »
Drive earlier and when I put my foot down all she does is splutter does this sound like coil pack
Offline Northy1985
Re: Splutter under load
« Reply #1 on: September 18, 2015, 05:52:32 pm »
Forgot to say she was cold and started up and ran sweet on low revs
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #2 on: September 18, 2015, 06:19:07 pm »
Could be fuel or electrical related
Only way to be sure is to get a VCDS scan and see if anything shows up
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #3 on: September 18, 2015, 06:35:38 pm »
Could be quite a lot of things, when was/were the spark plugs / cam follower / PCV last changed?
Scan (Save) / Clear / Drive it / Scan again, to be closer to a real solution. :happy2:
Offline Northy1985
« Reply #4 on: September 18, 2015, 06:51:57 pm »
It had new cam follower/ pcv/ dv and health check nor long befor i brought her as it was dont just befor being mapped. Just seemed to splutter when turbo kicked in ar low speeds drives nice. When i used it weekend just gone this problem didnt exist. Its only today it done it as i was dropping the car off.
Offline Northy1985
« Reply #5 on: September 18, 2015, 06:54:17 pm »
Best way to desbribe is feels like traction control kicking in. But was turned off so its not that
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #6 on: September 18, 2015, 06:59:17 pm »
Is it mapped?
TBH mate, you can start chucking cash at it based on other peoples opinion, but usually when you get it scanned it will give you a good idea where to start spending your hard earned.
There's a list on here of people who have VCDS, good luck mate. :happy2:
Offline Northy1985
« Reply #7 on: September 18, 2015, 07:08:26 pm »
It is mapped yes. Just strange that low revs it's fine and in neutral she revs up nicely but under loud it splutters
Offline mdmay
  • -Given: 38
« Reply #8 on: September 18, 2015, 10:34:30 pm »
Definitely coil pack
Regards,
Mike
Offline Northy1985
« Reply #9 on: September 19, 2015, 07:03:34 pm »
Changed all 4 coils and plugs and problem solved. What I call cylinder 4 coil looked like it was burning out as it looked and smelt different the the others
