Author Topic: Experiences of eBay downpipe/sports cat?  (Read 19212 times)
Offline Mitch H
  • -Receive: 25
Re: Experiences of eBay downpipe/sports cat?
« Reply #15 on: September 23, 2015, 04:17:05 pm »
If your buying silencers or cats then yes you can see why people spend abit more. But when it's just a decat all it is, is some stainless pipe with some welds and if milltek welds crack then what's the point in the extra £££
Offline th3_f15t
  • -Receive: 183
« Reply #16 on: September 24, 2015, 05:39:54 pm »
In defence for Milltek, they sell thousands and thousands of exhausts so the likely hood that failures happen and get publicised is much greater than brands who aren't as numerous.
Nigel at BCS explained this one, the cheaper sports catalytic converters don't use as good quality material inside them (mostly the rare earth materials) which mean they wear out after a few years whereas a catalytic converter with better materials will last much longer.
It comes to how long you plan to keep the car for, and also other supporting modifications should be taken into account. Running a lower engine mount upgrade (either insert or full replacement) will put less strain on the exhaust system and thus help preserve life.
Offline Vintyd
« Reply #17 on: September 28, 2015, 12:22:04 pm »
Tempted to go for the Ebay downpipe/sports cat that looks to be the Direnza, so would fiiting the ECS Dogbone mount and the SP ALK help with it not breaking in a few years?
Offline th3_f15t
  • -Receive: 183
« Reply #18 on: September 28, 2015, 11:01:32 pm »
The short answer is yes, at least in terms of the flexi pipe.
Offline Vintyd
« Reply #19 on: September 28, 2015, 11:21:32 pm »
Cheers, I'm guessing the sports cat will not be the best due to the price but what I was wondering is will the car fail on emissions if the cat was gutted whenever it does fail?  Would be nice if you could then gut the cat when it fails and visually for mot would pass as there is what looks like a cat still on the car if that makes sense  :happy2:
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #20 on: September 28, 2015, 11:25:19 pm »
I'm going for the BCS cat back and probably a cheap down pipe initially. Then upgrade at a later date.
#1493
Offline th3_f15t
  • -Receive: 183
« Reply #21 on: September 29, 2015, 12:41:54 pm »
It depends how friendly you are with your MOT station. A cheaper cat will last a few years so if you're not planning on keeping the car forever or swapping the pipe for a better design at some point then it's a quick fix but I'd spend more initially on just a downpipe and sports cat leaving the stock cat back system as you'll see more gains with a downpipe than a cat back.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #22 on: September 29, 2015, 10:05:01 pm »
I want noise.  :happy2:
#1493
Offline hlcst
« Reply #23 on: September 30, 2015, 07:09:26 pm »
This is why you don't want to buy an eBay/Direnza sport cat
This is what happened to me this morning, it has only done about 1k miles! Luckily I bought @mvb12 decat last week so as soon as that arrives I will be straight into my mates workshop
Offline Mitch H
  • -Receive: 25
« Reply #24 on: October 01, 2015, 12:14:00 pm »
Just weld it back on?
Offline hlcst
« Reply #25 on: October 01, 2015, 12:47:38 pm »
Not worth welding it back on mate the decat should be here soon. If you look at the image of the sport cat here http://www.direnza.co.uk/vw-golf-mk5-sports-cat-exhaust-downpipe.html you would expect that 1 prong falling off wouldn't be that bad but that image is a lie! There is no nice little bracket they have just directly (and poorly) welded the prongs directly to the pipe in 2 places, I will however get my mate to fix it when its off and make it look more like the image and sell it on
Offline gilesthedog
  • Happy GTi owner
« Reply #26 on: October 06, 2015, 09:32:23 am »
Facing the same dilemna about the costs for a branded system I decided to wait and just fit a s/s downpipe with sports cat, http://www.ebay.co.uk/itm/VOLKSWAGEN-GOLF-MK5-GTI-2-0-FSI-TURBO-200CPI-3-SPORTS-CAT-EXHAUST-PIPE-/230865921656?hash=item35c0ae6678
Within a few days the exhaust system warning light came on, even after reset it came back so waited for re-map before taking action. Even after the remap the second lambda was showing a problem with the gas level not being in the correct range so the mapper disabled that sensor and reset the light, it's never returned. 3 months later the MoT came around, no problem at all with emission levels and a straightforward pass. I get the quality/materials difference and would like to get a full pukka system at some point, just a case of having a grand to throw at it.
Offline Owencash
« Reply #27 on: October 17, 2015, 04:23:06 pm »
I've had no issues with my cheap eBay sports cat, been on the car for 6000 miles,  I fitted mine in conjunction with a dog bone bush and the car is transformed ! Nice and quiet until you put your foot down and it sounds a lot better,
Offline MK1Campaign
« Reply #28 on: October 17, 2015, 04:55:59 pm »
Which one did you buy.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #29 on: November 05, 2015, 05:12:00 pm »
Well. My cheap eBay decat is now fitted and sounds great.  :happy2:
#1493
