Author Topic: milltek tbe with out map !!  (Read 6387 times)
Offline candy turbo
Re: milltek tbe with out map !!
« Reply #30 on: December 23, 2009, 09:38:16 pm »
all i want to know really is if i fit the milly down pipe &cat will it bring fault lights on the dash and / or upset the idle ? i ll contact milltek in the new year to see what they have to say
 it does state on there web site that its designed to go on standard car  :smiley:
Offline Toast
« Reply #31 on: December 23, 2009, 09:41:32 pm »
Shouldn't be a problem mate  :happy2:  I've been runing my ED30 with my giac map switched off for a bit and it does throw any lights on  :smiley:
« Reply #32 on: December 23, 2009, 09:44:39 pm »
i ran mine with the full system on with just stage 1 on and after a 200mile trip the light came on but have vag com so i turned it off and after about 20 or so miles it did the same again so just put stage 2 map on to solve it  :laugh: it made no changes to the idle or anything while the light was on
Offline candy turbo
« Reply #33 on: December 23, 2009, 09:57:58 pm »
 is yours 100 cel cat on your car mat ? blueflame ?
« Reply #34 on: December 23, 2009, 09:59:01 pm »
yes mate it is  :smiley:
Offline candy turbo
« Reply #35 on: December 23, 2009, 10:08:25 pm »
sounds like this could be the case , milltek do a 200 cel sport cat or a 100 cel race cat , ill find out from milltek in jan  :happy2:
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #36 on: December 24, 2009, 09:01:15 pm »
There's only one part shown for the downpipe that I know of on the milly website... how can I tell if my downpipe is 100 or 200 CEL when it arrives?
Offline candy turbo
« Reply #37 on: December 27, 2009, 04:23:20 pm »
if you order a normal down pipe / cat it will be 200 if you ve ordered a motorsport one it will be 100   hth  :santa:
Offline stiggy
« Reply #38 on: December 27, 2009, 05:26:15 pm »
I know it's not a milltek, but i've had my exhaust fitted now and driven for around 150 miles with no light so far - it's a blueflame turboback
MkV GTI Edition 30 - 5 door - DSG - Diamond Black - RNS 510 - Now with a hint of blueflame.....
  • MUBster DUBster
« Reply #39 on: December 27, 2009, 06:17:12 pm »
Thanks for the info candy turbo.  A few more questions...
1) Assuming the 100 CEL gives better performance gains, what is the performance difference between the 200 and 100 CEL downpipes?
2) Will the car pass MOT emissions test with the 100 CEL downpipe fitted?
3) Is there a difference in the engine/exhaust note?  Which downpipe sounds better?
Thanks in advance.
Offline candy turbo
« Reply #40 on: December 27, 2009, 10:26:04 pm »
i dont think the 100 cel difference will make that much difference in noise or performance BUT  i suppose the die hard guys out there might say different  as for the MOT  i think you may be taking a risk with the 100 cel cat but again i m not 100% sure
