Author Topic: CD player interference  (Read 2802 times)
Offline carmaduk
« on: September 24, 2015, 09:54:32 am »
I've just used the 6 disc changer since having my car and when driving I get interference through the speakers.
Like the noise you would normally get when fitting an aftermarket amplifier.
Any ideas?
thanks in advance
05 5dr GTi black - APR stage 2+  Stage 2 Airtec FMIC - VWR 360mm front BBK inc FK spacers - Milltek turbo back resonated inc Hi-Flow CAT and downpipe - Forge Twintake - APR HPFP - Whiteline anti-lift - SMFW conversion - Stage3 Clutch
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=stcohlfnlp4o19gvrkoifctub6&/topic,90967.msg917089.html#msg917089
Re: CD player interference
« Reply #1 on: September 24, 2015, 10:33:00 am »
What head unit do you have?
05 | Tornado Red | DSG
Offline carmaduk
« Reply #2 on: September 24, 2015, 10:52:22 am »
Just trying to find out the model number but the 100s of pictures I've looked at seem slightly different.
It's not a touch screen or NAV but does have 6disc changer in the armrest.
I'll keep looking.
Offline carmaduk
« Reply #3 on: September 24, 2015, 10:54:16 am »
Found it....
RCD500
Offline carmaduk
« Reply #4 on: September 24, 2015, 10:57:05 am »
I've also found on one of the receipts from Awesome Gti
VAG-7N0907530C Can Gateway Interface - supplied and fitted
Do you know what this was for?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #5 on: September 24, 2015, 11:14:24 am »
I upgraded to an RNS510 and the cd player sounds like you described. This is because a pin needs to be switched i didn't bother as i don't use the cd player.
Usually the can gateway would be changed to stop battery drain when upgrading the head unit. Maybe the headunit was switched out before the car was sold.
Offline carmaduk
« Reply #6 on: September 24, 2015, 11:41:02 am »
Ah that would perhaps make sense in the way that the pin was switched if the car had an upgraded unit and gateway fitted but now if the upgraded headunit had been removed and the pin not switched back this could be the issue?
Is the pin on the headunit or the wiring?
-- It wouldn't make sense to the the gaetway fitted with the standard stereo would it?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #7 on: September 24, 2015, 01:02:39 pm »
I had 20 mins to spare and although i don't use the cd player in the armrest, due to my OCD i like things to be working as they should.
I moved pin2 CD Ground black wire to pin 3 (pin 3 was empty)
A few pics.
You don't need a pin removal tool for this one. Unclip the blue connector from the main harness block.
Remove the blue part this locks the pins in place.
Use a small screwdriver to push the locking tab on the pin down so you can gently pull on the wire and slide it out.
And the cd's sound perfect now.  :happy2:
Offline carmaduk
« Reply #8 on: September 24, 2015, 01:24:02 pm »
Mate you're a star, I shall give it a go and see what is does, it certainly doesn't do it when just using the headunit to play a CD only the CD multi-changer.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #9 on: September 24, 2015, 01:39:39 pm »
Remember you should be moving from pin 3 to pin 2. If its already in pin 2 there must be something else causing it.
Offline carmaduk
« Reply #10 on: September 24, 2015, 01:51:55 pm »
Ah yes - good point  :wink:
Offline carmaduk
« Reply #11 on: September 28, 2015, 01:36:47 pm »
Bit of an update on this - oddly when using different CDs there is no interference so perhaps just the CD rather than the headunit or cd-changer > most odd!
