Author Topic: Vagcom/vcds in Portsmouth/Southampton?  (Read 1155 times)
jordan7050
« on: September 25, 2015, 05:52:39 pm »
Random one and probably unlikely but anyone with a vagcom/vcds in portsmouth/hampshire area?
thanks
Offline v4rley
  • -Receive: 104
Re: Vagcom/vcds in Portsmouth/Southampton?
« Reply #1 on: September 25, 2015, 06:02:47 pm »
There is a section dedicated for such request.
Look here
If no luck im on the IOW if you get desperate  :wink:
« Last Edit: September 25, 2015, 06:09:39 pm by v4rley »
jordan7050
« Reply #2 on: September 25, 2015, 06:04:18 pm »
thanks for that  :happy2:
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #3 on: September 25, 2015, 10:56:48 pm »
What did you need doing?
jordan7050
« Reply #4 on: September 26, 2015, 12:30:00 am »
I'm just wanting to check to make sure the cars running the way it should. I had a problem with cruise control, so got the stalk replaced. The light illuminates when the switch is in the on position (this was intermittent before) but when i press the set button nothing happens, i assume this is down to either a fault and/or the brake light switch. just want to know if theres any fault codes before replacing parts
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #5 on: September 26, 2015, 07:13:23 am »
I'm in sunny Winchester so not a million miles from you. Drop me a PM if I can help.
