Author Topic: Golf gti mk5 no turbo power  (Read 4303 times)
Offline schmidt_vr6
« on: September 25, 2015, 07:36:09 pm »
Hi
My mate has a golf Gti and we've been out in it today and at high speed the turbo dies. Feels as tough theres no turbo power. As if we're driving a 2.0 Non Turbo.
It seems to spool upto about 2 and half rpm. Then you feel a little surge and that's it no turbo.
Once you switch engine off it's back to normal again
Any ideas guys?
Offline dan930
  • -Receive: 56
Re: Golf gti mk5 no turbo power
« Reply #1 on: September 26, 2015, 02:39:51 pm »
Will it be a boost leak somewhere?
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline th3_f15t
  • -Receive: 183
« Reply #2 on: September 26, 2015, 07:03:23 pm »
If the problem is going away upon turning the ignition off I'd suspect there is an electrical system putting the engine into a safe mode. A sensor somewhere might be failing so you'll need to run a diagnostic to see what, if any, error codes are being thrown up. If it was a boost leak you'd get no boost constantly rather than a few times then it going.
Offline schmidt_vr6
« Reply #3 on: September 28, 2015, 08:48:27 pm »
I've had the car scanned today for fault codes and it's bought up one fault.
PO234 - Boost Pressure Regulation (Overboost Condition)
Any ideas guys?
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #4 on: September 28, 2015, 08:50:09 pm »
Offline schmidt_vr6
« Reply #5 on: October 13, 2015, 10:48:40 am »
Had the car on the ramp, Tried a new Diverter Valve, Problem still there.
Tested the Turbo via Measuring Block on VAGCOM. It just wasn't getting the boost needed. So mechanic said I think the Turbo Vanes are clogged and needs to be sent off for testing.
Anyway whilst removing the Turbo we noticed that the N75 Valve one of the T-Piece had broken and was losing boost pressure causing the engine to go into limp mode.
A new N75 Valve is on order so we think its that what's causing the problem. So I shall report back if the fault is cured. Wish me Luck
Offline schmidt_vr6
Re: Golf gti mk5 no turbo power - FIXED/SOLVED
« Reply #6 on: October 14, 2015, 10:55:21 am »
All Fixed. Was The N75 Valve That Was Shot  :driver: :driver:
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #7 on: October 14, 2015, 12:20:56 pm »
Turbo Vanes!?!?! This is a petrol turbo with an internal wastegate, not a VNT Turbo....
At least it's sorted, you're lucky it didn't cost you a turbo as it could well have blown itself up. Luckily the ECu did its job, realising it had no control over the boost pressure.
