Author Topic: golf mk6 gti to R swap!!  (Read 29287 times)
Offline menios80
Re: golf mk6 gti to R swap!!
« Reply #30 on: September 29, 2015, 06:59:17 am »
During summer heat i notice strange behavior from my dsg hesitation at downshifting etc..my guess and after i have a bad mechatronic to play at home the and after reading a lot i fond out that the biggest problem for bad units is heat and also for slipping since when the oil gets really hot the pressure on gearbox drops..Previous week i install custom dsg oil external cooler.
The results..: slipping i have occured since k04 awd at 2bar is gone(as fwd there was no slipping as there where ways for power to be lost in spinning) and the best think no hesitate and no power loss even after 5-6 full boost runs 2-3-4 gear and dsg fart seems more powerfull.I'm really happy with the results.
Στάλθηκε από το SM-G920F μου χρησιμοποιώντας Tapatalk
Offline menios80
« Reply #31 on: November 06, 2015, 10:05:41 pm »
Today i made a run 1th-4th gear roll 2.0bar boost no meth.
Offline Martk19871
  • Va Va Voom
« Reply #32 on: November 07, 2015, 07:45:59 am »
Oh good lord. Incredible build!  :congrats:
Offline Flint
  • -Given: 17
« Reply #33 on: November 07, 2015, 08:13:10 am »
Very well done.
Offline Hannakournikova
« Reply #34 on: November 07, 2015, 10:12:18 am »
Great work!
dansmith180
« Reply #35 on: November 19, 2015, 09:45:54 pm »
Awesome build mate, any chance you have the part numbers for the Passat alloy bits?
Offline menios80
« Reply #36 on: November 20, 2015, 07:13:55 am »
There are many part number from passat 3C/cc
http://m.ebay.de/itm/VW-Passat-3C-2-0-TDI-Traggelenk-Querlenker-Achsaufhaenung-Vorne-Rechts-/271884471988?nav=SEARCH
http://m.ebay.de/itm/VW-Passat-3C-BJ07-Kombi-Querlenker-Links-Vorne-/391158566537?nav=SEARCH
Send you 2 links as example!
Offline ProffB
« Reply #37 on: March 14, 2019, 07:29:47 pm »
Thanks. How did you wire up the additional fuel sender (suction jet pump)?
