Author Topic: golf mk6 gti to R swap!!  (Read 27005 times)
Offline menios80
« on: September 25, 2015, 09:19:11 pm »
Another mk6 gti dsg gets awd dsg swap and R original look.after months of searching for parts i finally finished my project.all parts working perfect no vag-com error second fuel sender is wired to dash haldex controller also.i tried to keep weight as low as possible compared to an original R i have lighter:
*front control arms and knuckle(passat cc)
*tt rs front brakes(lighter than R)
*rear awd subframe alloy from r32
*rear crush bar from a3 which is alloy
*enkei rc-t4 wheels lighter from stock
Other mods to the car:
*Original R optic
*h&r golf mk6 R springs(gti springs are soft for the awd weight)
*tt 8j front top mounts
*k04 turbo with forge wg
*lnf injectors with custom tune
*76mm custom exhaust with 100cell hjs cat
*treadstone intercooler custom pipes
*aem methanol kit
*custom intake
*gfb blowoff valve
*pbc electronic boost controller
*defi 52mm boost gauge
*original rear pdc
And other things that maybe i forget.
All things works perfect.i connect second fuel sender to my dash and an expert make the decode for my abs unit to work with Awd.Not even one error to vag-com scan,really huppy from the results!!
« Last Edit: September 25, 2015, 09:34:08 pm by menios80 »
Offline th3_f15t
  • -Receive: 183
Re: golf mk6 gti to R swap!!
« Reply #1 on: September 26, 2015, 06:47:27 pm »
Mate, this is seriously impressive. Wrong section, should of put this in Member's Rides so more people will see it and appreciate all your hard work. I wanted to do the same things to my mk5 GTI but ended up getting a mk6 Golf R instead as it was just easier.
Offline menios80
« Reply #2 on: September 26, 2015, 07:51:03 pm »
Thanks mate!!maybe the admin could move this if he wants and see it!!it's not an easy swap if you want to be like stock it want many many things that i might have forgot to mension.Mk6 R...almost the same... ;) i'm now planning on turbo upgrade gtx3071 is already home! :)
Στάλθηκε από το SM-G920F μου χρησιμοποιώντας Tapatalk
  • -Receive: 442
« Reply #3 on: September 26, 2015, 08:45:28 pm »
Brilliant work and a credit to you
Offline th3_f15t
  • -Receive: 183
« Reply #4 on: September 26, 2015, 09:09:10 pm »
I'm also planning a GTX3071R turbo but I've read a lot of good things about the TTE420 turbo as well. I'm currently deciding what I want to do in terms of long term plans.
Offline menios80
« Reply #5 on: September 26, 2015, 09:20:34 pm »
Tte420 is a modified k04.what ever you do  it will be a k04 a midturbo,the stock turbo manifold can handle too much power.I have seen and ttrs turbo's modified to fit 2.0tfsi they stiil have temperature problems an short time of life.i will make a turbo up set up for gtx3071 i will keep you inform.
Check this s3 8p from Greece with gtx3071 plus meth at 2.3bar of boost!!!
« Last Edit: September 27, 2015, 10:54:08 am by menios80 »
Offline th3_f15t
  • -Receive: 183
« Reply #6 on: September 27, 2015, 09:59:18 am »
Yeah... That is savage! Thing for me is I spend a lot of my time driving in the mid-range so a turbo with good mid range torque probably suits my needs well enough. But I think with the right modifications a GTX3071R should be just as lively, but will be interesting for your feedback once you go down that route.
Offline menios80
« Reply #7 on: September 27, 2015, 10:58:07 am »
Yes of caurse i will leave a feedback for all,the built and the results and dyno!i bought a gtx3071 with new garrett vband housing 0.61AR for lower spooling.I will install it with the best tubular manifold in the market in my opinion which is made in Greece.
Offline menios80
« Reply #8 on: September 27, 2015, 11:06:14 am »
Check out my turbo and turbo mani.
  • -Receive: 442
« Reply #9 on: September 27, 2015, 11:44:27 am »
That manifold is a work of art
Offline menios80
« Reply #10 on: September 27, 2015, 11:56:06 am »
If and other member are interesting i can arrange a group buy.I know the fabricator and you have many option in build.With external or w/o ,with t3,t25,vband inlet. :)
Offline th3_f15t
  • -Receive: 183
« Reply #11 on: September 27, 2015, 12:42:04 pm »
If the price is good, I might be interested in a manifold as well.
Offline menios80
« Reply #12 on: September 27, 2015, 12:48:36 pm »
I can take an offer for 5pcs and 10pcs.I will let you know.i think it would be good even as decoration to the living room..
Offline toosmiles
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92286.0.html
« Reply #13 on: September 27, 2015, 04:33:58 pm »
cracking build m8 :happy2:
that video is ananimal,something in the future id like also
maybe interested in the manifold aswell
Golf R mk6 R-tech tuned GTX3071r
Offline toosmiles
  • -Given: 22
« Reply #14 on: September 27, 2015, 04:38:53 pm »
also,is the a3 crush bar a straight swap over to the mk6 golf r?
