Author Topic: Tornado red GTI R-Tech stage 2  (Read 20379 times)
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Tornado red GTI R-Tech stage 2
« Reply #30 on: August 03, 2016, 04:59:43 pm »
Give Nige a call at least while you're looking around. He'll sort you a good forum price, and the Powervalve cat backs are 3". Perfect accompaniment to your downpipe! He'll make sure you get the right connector, and you'll get excellent support if you need it after the sale. Not to mention the quality of the materials and the fit.
I'm honestly not on commission by the way, but if he offered me a job....
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
« Reply #31 on: August 03, 2016, 05:14:14 pm »
Haha. I think you've got the job mate  :happy2: I'll get in contact soon.
I'ts been struggling on cold starts recently, cranking between 7-10 times before it fires which is strange. So I'm kind of hoping that it's the hpfp and that buying the loba will kill 2 birds with one stone. Fingers crossed
Instagram: stu_nc88
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #32 on: August 03, 2016, 05:30:14 pm »
Can you hear the pump priming when you open the driver's door?
Offline Paradox1
  • -Given: 41
« Reply #33 on: August 03, 2016, 05:40:30 pm »
have you changed the spark plugs? I think it NGK but cant remember what model it is that works well with remapped tfsi engines.
I'll have a look
Offline stuart-88
  • -Receive: 21
« Reply #34 on: August 03, 2016, 06:33:38 pm »
Good point. No I can't, tried a few different times too.
Haven't changed the Sparks plugs, they were done last August at VW and I have done about 2000 miles since, I was hoping to rule that out straight away
Instagram: stu_nc88
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #35 on: August 03, 2016, 06:35:41 pm »
It's not very loud. It's a high-ish pitched whirring noise.
If you definitely can't hear it, do your interior lights come on when you open the door?
Offline stuart-88
  • -Receive: 21
« Reply #36 on: August 03, 2016, 07:56:23 pm »
I'll keep having a listen out for it, but I couldn't hear it at all. Interior lights don't come on no. Then again I had this problem before with my old tdi, where I had to sort out the contacts in the interior light unit.
Instagram: stu_nc88
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #37 on: August 03, 2016, 08:03:13 pm »
I might be wrong, but I think it's the same switch in the door that turns your interior lights on that tells your fuel system to prime.
If it's not getting that signal, it'll struggle to get up to pressure when it's cold. Especially if it's been sat overnight.
That's probably a better case scenario than the actual pump being faulty! Get it checked out.
Offline stuart-88
  • -Receive: 21
« Reply #38 on: August 03, 2016, 09:20:49 pm »
I've had a Google. If it's the door switch I should be getting a whole other bunch of issues too, auto lights, alarm, anti theft locks not kicking in etc. I'm not having any of them problems. I'll keep listening out for the fuel pump, but it's parked up until Sunday now unfortunately! I need to get it scanned again, just to see if anything has flagged up
Instagram: stu_nc88
Offline stuart-88
  • -Receive: 21
« Reply #39 on: September 10, 2016, 12:40:22 pm »
Not much to update! Helix clutch going on next weekend which is much needed. It had a full 2 stage detail a couple of weeks ago finished off with CQuartz UK. Paint work was really bad so it looks so much better. Actually red again. Also fitted a 300mm OMP quick release steering wheel, mainly for security reasons as its parked up for weeks on end.
Instagram: stu_nc88
Offline Martin_jk
  • -Given: 19
« Reply #40 on: September 10, 2016, 04:10:07 pm »
Looks really tidy mate the paint looks awesome now, love the way the intercooler looks behind the front grills too!
« Last Edit: September 10, 2016, 04:13:27 pm by Martin_jk »
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #41 on: September 10, 2016, 07:12:16 pm »
Good stuff. I've got the Helix myself. It's very good, deals with the 345lb/ft I'm currently putting through it without even the slightest hint of slip. Acts like stock, just with a heavier pedal. Unless you've got weak legs you'll be used to it within 30 miles of driving!
Offline stuart-88
  • -Receive: 21
« Reply #42 on: September 11, 2016, 12:14:06 pm »
Thanks mate  :happy2:
Yeah I quite like the feel of a heavier clutch so I'm looking forward to that!
Instagram: stu_nc88
Offline Optimistictim
« Reply #43 on: September 11, 2016, 08:24:40 pm »
I've just bought a Tornado Red GTI and if I can make it look as half as good as yours I will be happy!
Sent from my ONEPLUS A3003 using Tapatalk
Offline stuart-88
  • -Receive: 21
« Reply #44 on: September 11, 2016, 09:39:06 pm »
Cheers mate! Appreciate it. If you'd have seen mine before you'll know anything is possible  :happy2:
Instagram: stu_nc88
