Author Topic: Why are my Top Mounts still knocking?!  (Read 2783 times)
Offline 18Edition30
« on: October 03, 2015, 08:46:10 pm »
Basically, changed my top mounts for new genuine items, the bearings and the mounts.
And they are still knocking when going lock to lock, you can feel them knocking/moving when someone moves the wheel lock to lock.
Currently on standard shocks with eibach lowering springs
What's causing this?
Can't be two faulty bearing sets?
Also had console bushes changed and a rack in the past few weeks.
Is it something else causing them to move/knock?
Thanks, any ideas appreciated!
« Last Edit: October 03, 2015, 09:02:40 pm by 18Edition30 »
Offline banksy21
Re: Why are my Top Mounts still knocking?!
« Reply #1 on: October 07, 2015, 09:06:58 pm »
have you fitted them the correct way?
Offline Llew
  • -Given: 45
« Reply #2 on: October 08, 2015, 02:31:40 am »
It's probably not the top mounts that's knocking check arb - drop links -subframe bolts etc
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline 18Edition30
« Reply #3 on: October 10, 2015, 06:40:34 pm »
It's definitely the top mounts knocking/moving, if you hold your hand on them you can feel it if someone else moves the wheel lock to lock.
Checked ARB, ball joints, subframe etc etc, still there!
Confused and annoyed!
Offline Morgen
  • 2008 DSG Edition 30
« Reply #4 on: October 20, 2015, 12:35:08 pm »
Same issue.. Replaced my knackered top mounts in July with brand new ones from pedders as I've got pedders coilovers. One side is still clunking its tits off and knocking away  :fighting:
