Author Topic: RCD 510 DAB, Kufatec Bluetooth, VW iPod Interface, DAB antenna  (Read 3351 times)
Offline zed4
    • New Forest Sports Car Hire
  • My Ride: 2006 VW Golf GTI DSG
« on: October 06, 2015, 02:25:08 pm »
Hi,
I've removed all the upgraded items I fitted to my girlfriend's GTI, so I've listed them on eBay:
RCD 510 DAB
http://www.ebay.co.uk/itm/231707439167?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Kufatec Bluetooth
http://www.ebay.co.uk/itm/231707439945?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
VW Glove Box iPod Interface and Cable
http://www.ebay.co.uk/itm/231707440298?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
I also have a new DAB antenna which I will list later tonight.
Cheers,
Dan
New Forest Sports Car Hire  - TVR Chimaera 400, Caterham Roadsport SV 140, Porsche Cayman S, BMW M135i
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
Re: RCD 510 DAB, Kufatec Bluetooth, VW iPod Interface, DAB antenna
« Reply #1 on: October 06, 2015, 04:23:02 pm »
How easy would it be to extend the glove box unit to my center arm rest to replace my CD changer?
Offline shoaybmakda
  • -Receive: 54
« Reply #2 on: October 06, 2015, 05:36:51 pm »
Might be a silly question - I have a mfd2 and high line with MFSW will the kufatec give me the same benefits listed?
Offline Rossimac
  • -Given: 78
« Reply #3 on: October 06, 2015, 10:52:59 pm »
My guess is that you'd have no Phone interface on the sat nav - you should have it on the Highline clocks though. I've got it with my RNS 510, fyi.
Offline zed4
« Reply #4 on: October 07, 2015, 10:29:43 am »
It has quite a long lead on it, so I would have thought it would reach the centre console ok. I'm not sure what's in the glove box CD changer, so I don't know what's involved in pulling it out. I would probably just hide the iPod interface box in the console somewhere and just have the Apple lead poking out through a small hole somewhere.
Offline zed4
« Reply #5 on: October 07, 2015, 10:30:28 am »
Yeah, you should be able to access all the info on the display in your dash. IT works with the steering wheel controls too. It will display phone numbers and the engine info on the dash display.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #6 on: October 07, 2015, 03:34:14 pm »
Regarding the ipod kit:
Does this work with the bog standard RCD300?
In what state does it charge the ipod? Only with ignition on, or will it keep charging with the engine off and locked up?
Do you know if it's compatible with a 4th gen Nano?
Edit - just read the update on ebay and seen it's only RCD310 up.
« Last Edit: October 07, 2015, 03:36:35 pm by AJP »
Offline Adam.P
« Reply #7 on: January 13, 2016, 01:21:31 pm »
Did you get boost to display through the E-MFA add on?
Offline Rossimac
  • -Given: 78
« Reply #8 on: January 14, 2016, 10:06:36 am »
Not with the GTI unfortunately - just reads N/A or 0.00
