Author Topic: 3dr Rear Speaker Upgrade - Gladen?  (Read 23644 times)
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
Re: 3dr Rear Speaker Upgrade - Gladen?
« Reply #15 on: October 13, 2015, 05:56:14 pm »
The Golf Mk5 kit. Which is the One 200 3 way setup.
#1493
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #16 on: October 17, 2015, 09:14:45 am »
Keep us updated with this mate, it'll be good research for me! It does sound like a quality set. Should have some nice depth with the 8".
Offline white91
« Reply #17 on: October 17, 2015, 11:36:07 am »
I've been trawling eBay for a set of these for a while
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #18 on: October 17, 2015, 12:46:57 pm »
I've ordered mine from Germaniks. Cheapest online for the setup. I will self install the speakers and then may take it to TeamSPB for an amp setup at a later date.
#1493
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #19 on: October 17, 2015, 02:59:12 pm »
Can't find the 3 way set listed on that site - how much did you pay, if you don't mind me asking?
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
#1493
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #21 on: October 17, 2015, 11:04:48 pm »
Here it is!!  :happy2:
http://www.germaniks.com/speakers/gladen-one-line-200-golf-5-3-way-system/
Cheers mate. I might just have to bite the bullet and get these ordered!
Offline loop
  • -Given: 26
« Reply #22 on: October 19, 2015, 06:28:54 am »
I am also looking to upgrade my front speakers (currently have the 10 speaker system with 3 ways in the front). Is it simply a case of removing the VW ones and replacing with aftermarket speakers of the same size? Does any wiring have to be changed, and are there any adapters needed at the headunit? (I have an RNS 510). Thanks.
‘05 GT, Retrofits: RNS 510 DAB+, R32 Highline Cluster, R32 MFSW, Mk6 Reversing Camera, 7P6 Bluetooth, TPMS, Cruise Control, VW MDI, Chrome switches, Blaupunkt THA 475 amp.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #23 on: October 19, 2015, 02:40:26 pm »
The Gladen setup is plug and play. If you go other aftermarket systems, you are going to have to cut and chop speaker wires.
#1493
Offline loop
  • -Given: 26
« Reply #24 on: October 20, 2015, 06:04:22 am »
I have some Rainbows was going to try them without an amp to start with just in place of the VW speakers, but I think they need an amp after looking at the instructions!
Offline xjay1337
  • -Receive: 377
« Reply #25 on: October 20, 2015, 09:36:47 am »
The decent speaker setups will need some cutting as the OEM wires will route to a crossover unit. From there you will need to wire from the outputs to the speaker.
Offline loop
  • -Given: 26
« Reply #26 on: October 21, 2015, 01:20:55 am »
Very true, I have the added problem of having 2 crossovers per door, not sure if there is enough space inside the door card to fit!
Offline xjay1337
  • -Receive: 377
« Reply #27 on: October 21, 2015, 11:11:27 am »
I managed to fit my Hertz ESKL 163 crossovers behind the doorcard.
The Hertz ones are massive. You should be fine .
Offline loop
  • -Given: 26
« Reply #28 on: October 21, 2015, 04:53:51 pm »
Did you fit an amp as well? If so whereabouts - under the passenger seat?
Offline xjay1337
  • -Receive: 377
« Reply #29 on: October 21, 2015, 10:32:13 pm »
Amp goes in the boot :) but come up with any solution.  As all depends on what amp youre using and how big it is etc. .
