Author Topic: 3dr Rear Speaker Upgrade - Gladen?  (Read 22931 times)
Offline loop
  • -Given: 26
Re: 3dr Rear Speaker Upgrade - Gladen?
« Reply #30 on: October 22, 2015, 08:05:10 pm »
Amp goes in the boot :) but come up with any solution.  As all depends on what amp youre using and how big it is etc. .
Considering the DLS A7 but it's very big so yes would have to go in the boot!
‘05 GT, Retrofits: RNS 510 DAB+, R32 Highline Cluster, R32 MFSW, Mk6 Reversing Camera, 7P6 Bluetooth, TPMS, Cruise Control, VW MDI, Chrome switches, Blaupunkt THA 475 amp.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #31 on: October 27, 2015, 07:31:10 pm »
Fitted my Gladen setup today. Lovely crisp sound.
#1493
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #32 on: October 28, 2015, 04:03:51 am »
Remind me what you're running them off again, hu/amp?
How you finding the 8s? They should create a nice bit of mid-bass.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #33 on: October 28, 2015, 04:14:22 pm »
Just an RNS510 :smiley:
#1493
Offline loop
  • -Given: 26
« Reply #34 on: October 28, 2015, 10:24:20 pm »
Are you not going to fit an amp?
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #35 on: October 29, 2015, 12:12:53 am »
I was going to, but really don't think it needs it now.
#1493
Offline xjay1337
  • -Receive: 377
« Reply #36 on: October 29, 2015, 10:03:22 am »
You will get a huge improvement in quality changing from the RNS/RCD to an aftermarket unit like a Pioneer or something :-)
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #37 on: October 29, 2015, 04:09:03 pm »
Agree. But I want to keep my RNS and I'll possibly look at the Gladen quad lock amp kit and a Mosconi 2 channel at some point.  :happy2:
#1493
Offline Rob.
« Reply #38 on: October 30, 2015, 07:01:50 pm »
Those 8" Gladen 3-ways look to be exactly what I've been looking for  :laugh:
I can't see the One Line 200 Extremes on the Germaniks site though.
Offline loop
  • -Given: 26
« Reply #39 on: November 03, 2015, 05:57:57 pm »
Do they come with cross overs and did you have to change any of the VW speaker wiring?
Offline xjay1337
  • -Receive: 377
« Reply #40 on: November 03, 2015, 06:55:38 pm »
Fair enough matey
Just accept you will get a huge jump in quality (even when amped) with a better head unit. :)
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #41 on: November 03, 2015, 08:10:44 pm »
Yes. Came with crossovers. You just ignore everything that's currently there apart from the 3/4 pin connector by the existing woofer. And feed from that into the crossovers which provide to the woofer, mids and tweeters.
#1493
Offline loop
  • -Given: 26
« Reply #42 on: November 03, 2015, 09:34:34 pm »
Ok cheers may order these myself as it sounds quite straightforward to install!
« Last Edit: November 03, 2015, 10:07:00 pm by loop »
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #43 on: November 03, 2015, 10:24:09 pm »
It's a pain to install. Have a heat gun or hairdryer at the ready to remove old lugs holding tweeters and other bits in. And also need to drill out the rivets for the old woofers and come up with your own mounting solution for the spacers as nothing is provided. Also nothing to mount the crossovers. Mine are just cable tied to the existing looms.
#1493
Offline loop
  • -Given: 26
« Reply #44 on: November 04, 2015, 12:19:13 am »
Oh ok, just thought it would be easier than the Rainbows I have as the Gladen speakers are the exact same size as the VW ones so thought they would be easier to fit...at least the door card should go back on easily enough!
