Author Topic: Any cruise control buffs?  (Read 1518 times)
jordan7050
« on: October 14, 2015, 12:08:28 pm »
So i've had the cruise control "replaced" at a garage and it doesn't set anymore.
It was intermittently indicating the green light on the dash before i had it replaced, now its been replaced it consistently indicates the green light then the switch is on but the "set" and "res" doesn't register on VAGCOM.
The steering control module is :1K0-953-549-AQ
Software number is:0070
And its a Highline (factory fitted)
Which stalk part number should be compatible with this steering control module as i believe they have fitted the wrong stalk.
Offline olsen-72
  • -Receive: 21
  • Redditch
Re: Any cruise control buffs?
« Reply #1 on: October 14, 2015, 03:01:24 pm »
What year is it?
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
jordan7050
« Reply #2 on: October 14, 2015, 03:20:16 pm »
2007 mk5 GTI with highline and MFSW.
The green light now indicates but "set" and "res" doesn't respond.
Going to try another stalk but if that doesn't work then i've got no idea  :sad1:
jordan7050
« Reply #3 on: October 14, 2015, 03:21:43 pm »
i read online that someone had a milltek fitted and the garage didn't reconnect the vacuum pipe to a butterfly valve on the exhaust and this prevented his CC from working, is this worth investigating?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #4 on: October 14, 2015, 04:23:54 pm »
U can check that stalk buttons in vcds to see if they work
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: October 14, 2015, 05:17:47 pm »
Version A are notorious for going wrong.  I would get a version G as they are the newest ones.
Sent from my GT-I9505 using Tapatalk
jordan7050
« Reply #6 on: October 14, 2015, 08:52:35 pm »
done a check on VAGCOM and the buttons don't register as an input when pressed which makes me think its the unit.
as for upgrading to revision g, how much would this cost as the garage has said its a big cost
jordan7050
« Reply #7 on: October 14, 2015, 09:07:17 pm »
do you have a part number mate?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #8 on: October 15, 2015, 08:09:11 am »
1K0 953 513 G
