Author Topic: Winter Protection  (Read 2619 times)
Offline LFCJosh
Winter Protection
« on: October 17, 2015, 12:37:40 pm »
Hi all,
So paint is in OK condition. Just bought the car, 11 years old and it's not too bad although does need a good machine polish.
I plan to get it detailed after the winter and obviously want to protect the paint in the mean time.
If I wax the car ready for winter on top on the slight swirls etc, will it be difficult to correct it after winter?
I currently use a quick detailer after washing which gives a hydrophobic layer but not as thorough as a wax.
What's the best plan for winter??
Offline Scoobykiller
Re: Winter Protection
« Reply #1 on: October 17, 2015, 12:40:29 pm »
No it will not make a difference mate. You can wax it now if you like
Offline white91
« Reply #2 on: October 17, 2015, 01:51:18 pm »
Buy a tin of FK1000P so easy to apply and very long lasting
Offline Horatio
  • -Receive: 39
« Reply #3 on: October 17, 2015, 01:58:10 pm »
If you can the spare the time, get a clay bar kit. You'll be amazed how much suface contamination it'll lift off. It will also give a really good bonding surface for your products, AutoGlym Super Resin Polish and Autogylm HD Wax will see you through a good 3+ months maybe longer.
Offline LFCJosh
« Reply #4 on: October 18, 2015, 06:10:13 pm »
Ok, cheers all.
I'll set aside a few hours one weekend to clay and wax it.
Offline Chris92
  • -Given: 33
« Reply #5 on: October 19, 2015, 11:11:58 pm »
Ok, cheers all.
Make sure you give it a polish to before waxing, srp will see you fine.
Offline GibboVR
« Reply #6 on: October 20, 2015, 09:52:52 am »
I recommend the Autofinnesse ultraglaze.
I've used it for several years before winter topped with a decent wax (i use autofinesse illusion) though i have used poorboys natty blue paste and its lasted the course of the winter.
Easy to apply and remove too.
Offline munchbunch
« Reply #7 on: October 27, 2015, 11:48:36 am »
Have you thought about using a sealant? I use Sonax Polymer Net Shield and it gives about 6 months worth of protection from the elements. Give it a hand polish then apply a couple of coats.
