Author Topic: RNS510 - latest firmware and maps  (Read 9643 times)
Offline GTi-Andy
« on: October 18, 2015, 11:06:11 am »
hi all
Whats the latest firmware and map versions for the RNS510
And has anyone got a copy of each please?
So much for keeping it standard!
Offline Pashka
Re: RNS510 - latest firmware and maps
« Reply #1 on: October 22, 2015, 09:54:01 am »
I have maps pal.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Bignod00
  • Ginsters are sh*tE!!
« Reply #2 on: November 18, 2015, 05:12:38 pm »
@GTi-Andy  did you manage to get hold of the newest maps in the end? Mine are in desperate need of updating! :ashamed:
Offline GTi-Andy
« Reply #3 on: November 18, 2015, 05:21:41 pm »
im on V12 maps and 5238 software now
Not sure if that's the latest versions though?
Offline Bignod00
« Reply #4 on: November 18, 2015, 05:40:07 pm »
You have PM! :smiley:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #5 on: November 18, 2015, 06:16:23 pm »
Latest maps are V13 (2016).
Latest firmware depends on the HU version.
A: 5238 modified
B to Q: 5274 modified
R to T: 6276 modified
Offline Bignod00
« Reply #6 on: November 18, 2015, 06:19:29 pm »
A: 5238 modified
Thanks very much for the info my good man. :happy2:
Offline loop
  • -Given: 26
« Reply #7 on: November 19, 2015, 03:20:04 pm »
Is there a risk of bricking the unit if updating the firmware? Last time I updated the maps only (V10-V12) and left the firmware alone.
‘05 GT, Retrofits: RNS 510 DAB+, R32 Highline Cluster, R32 MFSW, Mk6 Reversing Camera, 7P6 Bluetooth, TPMS, Cruise Control, VW MDI, Chrome switches, Blaupunkt THA 475 amp.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #8 on: November 19, 2015, 04:26:58 pm »
Source the firmware from the right site, burn it in a good CD and you'll be fine. Just follow the instruction given for that procedure.
Of course messing with the firmware is a risk. Updating maps is risk free for bricking the radio, AFAIK. You just lose the maps at the worse chance.
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« Reply #9 on: November 24, 2015, 07:56:59 am »
Hi Gents.
I have a RNS510 DAB - 1T0035686C which is running 5218 firmware and map version 7918.
What firmware and map version should I upgrade to......and what benefits will the upgrade bring? (Or is it best to leave well alone?!)
I upgrades my old RNS 510 years ago and gained full 7 digit postcode entry for the navigation system so what are the changes now?
PR
Offline Pashka
« Reply #10 on: November 24, 2015, 10:49:14 pm »
Hi Gents.
PR
Leave FW the same, just upgrade maps to newer, because your maps is V9, the newest is V13, most popular at the moment V12.
droomurray
« Reply #11 on: January 12, 2016, 01:55:02 pm »
Hi does anyone have the md5 checksum for the RNS_510_FW_5274_update_modified.iso file so I can check the one I found is valid ?
Drew.
Offline shoaybmakda
  • -Receive: 54
« Reply #12 on: January 21, 2016, 08:38:25 pm »
have downloaded the maps but the file is coming up as 6GB? is this correct? as it won't let me move onto my SD card or burn onto DVD as the file is too big
« Last Edit: January 21, 2016, 08:40:16 pm by shoaybmakda »
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #13 on: January 21, 2016, 08:58:34 pm »
Are you using the SD Card tool? I've never used it. I just burn and copy DVD.
Offline Pashka
« Reply #14 on: January 21, 2016, 09:17:30 pm »
use dual layer dvd.
