Author Topic: p0299 underboost  (Read 3068 times)
Offline cutchie
p0299 underboost
« on: October 19, 2015, 11:33:20 pm »
Anyone ever seen this fault when it's not pcv, dv or intercooler pipes? According to some logs I ran demanded boost was 2000mbar and I was only producing 1300mbar? And for referance my maf reading is 130 g/s peak.
Car also has a decat downpipe and pops and bangs loads but stopped when I disconnected the maf.
Can anyone help I'm dying to get the car mapped to the stage 2 that I've got the bolt on mods to hit
Re: p0299 underboost
« Reply #1 on: October 20, 2015, 10:05:05 am »
Going by those numbers that's 4psi and 162hp.  It must feel pretty sluggish?
It's either a massive boost leak or an N75 / wastegate problem I'd suggest.
Offline cutchie
« Reply #2 on: October 20, 2015, 05:12:17 pm »
Well my last car was an in between car, 1.8tds fiesta so anything would be quicker but yea it feels like it's holding back! I can't find a boost leak, I may change the intercooler to the s3 type to rule that out, I might try and replace the n75 valve but I hear it's a nightmare thanks for the reply.
« Reply #3 on: October 21, 2015, 02:20:32 pm »
I'd expect to see a fault code for the N75 though.  "Set point not reached" or something like that.  They do fail though, so might be worth changing, and yeah, it is a pig!
Offline cutchie
« Reply #4 on: October 21, 2015, 05:27:18 pm »
The fact that it's popping so much makes Me think it could be the  wastegate (but I'm no expert) it could literally pop 10 Times on over run! Sounds good but it's Defo not right lol
« Reply #5 on: October 22, 2015, 04:16:36 pm »
Is that with the standard exhaust?  You usually get a bit of popping on the over run with an aftermarket exhaust as the standard one absorbs a lot of that, but if yours is stock, sounds like the fuelling is all over the place!  Popping is basically fuelling exploding in the exhaust and not related to the Wastegate directly.
Offline cutchie
« Reply #6 on: October 22, 2015, 04:46:26 pm »
When I say popping I mean it's loud enough to scare people on the footpath Lol  surprisingly it's quite easy on fuel 35/38 is quite normal.
