Author Topic: Engine 'shutting down' after 15 minutes  (Read 2744 times)
Offline john87
  • -Receive: 53
« on: October 23, 2015, 08:35:29 am »
Yesterday was the first time I'd drove my R32 after two weeks, and it started and drove as per usual.
On the road home, I pulled away from some traffic lights when suddenly all the gauges dropped to zero and I lost all power. I pulled over, and tried to restart, however no lights appeared on the dashboard, as if the battery was dead.. however the stereo and headlights stayed on as normal  :confused:
After a walk round the car, I tried again and it started as if nothing had happened!
The same situation occurred again today after approximately the same amount of time. After a quick google, I found a post relating to a faulty ignition relay.
Has anyone else had a similar issue? I'm going to Vagcom it tonight to see if it's raised any codes.
Redemption
Re: Engine 'shutting down' after 15 minutes
« Reply #1 on: October 23, 2015, 01:56:02 pm »
Same happened to me in my R32 although the instrument cluster was cutting out and flashing on and off. Was traced to a faulty main relay in the fuse box in the engine bay. There was a revised part released some time ago.
Offline john87
  • -Receive: 53
« Reply #2 on: October 26, 2015, 09:55:27 am »
That's exactly what is was  :happy2: ignition main circuit relay.. ended up calling the AA out after the car cut out 5 times within 10 minutes. Guy was an Edition 30 owner and knew his way round a Golf  :drinking:
Offline Rasco
« Reply #3 on: April 05, 2016, 04:35:43 pm »
I think I have the same issue, can you recall which relay it was? there are two apparently? http://www.autogenius.info/en/volkswagen-golf-5-fuse-box-diagram/
Offline Rasco
« Reply #4 on: April 06, 2016, 01:27:21 pm »
so the VW dealer has found the fault on mine, apparently its the terminal 15 supply relay 433?
Offline john87
  • -Receive: 53
« Reply #5 on: April 15, 2016, 10:02:47 am »
That sounds about right, can't remember exactly what relay it was but it controlled part of the ignition circuit and began with 4**
Offline Rasco
« Reply #6 on: April 15, 2016, 12:29:55 pm »
there are 2 relays in the engine bay fuse box, both are to do with the main ignition circuit it was one of those, no issues since the fault was repaired, but £80 odd for the diagnostics and the part, to be fair they had the car for a week and ran it about 10 times so they weren't to harsh with the charges!
