Author Topic: RNS 510 DAB Version  (Read 2078 times)
Offline Tr0nic
RNS 510 DAB Version
« on: October 23, 2015, 11:04:36 pm »
Hi Guys !
I've finally decided that my RCD300 should go and make way for a nice RNS 510 with DAB+ and an SSD !
I'm doubting between the 1T0 035 686 E or F version ... (even an H version but I can't even find it on ETKA !  )
F should be slightly newer then E ?
Found them on ebay, priced like £650 for E and £880 for F version.
HELP :driver:
Can't find much information about what the differences are, what the best choice is !  :happy2:
If anyone can help me see it a bit clearer, I would be very grateful  :drinking:
Cheers !
Milltek Catback Non Resonated - K&N panel filter with Carbonspeed, NQSBBK front, Caddy rears, CF engine cover, Bilstein B8 with Eibach Prokit, DS2500 all around
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
Re: RNS 510 DAB Version
« Reply #1 on: October 24, 2015, 03:32:23 am »
Seems expensive. I paid £439 for an R SSD but without DAB.
#1493
Offline SI-R32
  • -Receive: 125
« Reply #2 on: October 24, 2015, 04:05:05 am »
Chasing newer and newer versions is pointless,  did that with standard 510,  3 different versions made bugger all difference,  now have 686c dab,  so no ssd but still no difference to my oem b version I started with,  yes the screen is led back lit,  do you notice,  not one bit,  just get cheapest dab you can as in 3 months they'll be another 100 new versions as vw pump them out left right and center changing the letter on the end for little pointless reasons
Offline cenobytez
« Reply #3 on: November 03, 2015, 12:41:36 pm »
dont forget that you will also need an aeriel convertor cable as the 510 has a different connector
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #4 on: November 06, 2015, 12:24:29 pm »
And new gateway if your car is pre 2007.
