Author Topic: Brake pad warning but brake pads fine?  (Read 1008 times)
Offline Sheeny94
« on: October 24, 2015, 03:30:52 pm »
Hi,
New to the mk5 golf gti scene but must say I'm loving my experience so far
One thing that is annoying me is the brake pad warning light being on despite my pads having plenty of meat left on them
Anyone know what might be causing this and how I can resolve the issue?
Thanks in advance for any help
Offline v4rley
  • -Receive: 104
Re: Brake pad warning but brake pads fine?
« Reply #1 on: October 24, 2015, 06:01:25 pm »
Common issue due to faulty connector, can either be coded out with VCDS or make a plug to join the connectors together will eliminate the fault.
« Reply #2 on: October 24, 2015, 06:41:50 pm »
On my lasses old golf I put a split in the connector then taped it up
Offline Sheeny94
« Reply #3 on: October 25, 2015, 06:33:32 am »
Thanks for the info chaps will get it done. Sick of the light every time I start the car up
Offline Wardy93
« Reply #4 on: October 26, 2015, 10:57:57 pm »
Also check your brake fluid level if its low this will bring the light on too  :smiley:
